Old 05-20-2011, 12:10 PM
10TRX41500's Avatar
10TRX41500 10TRX41500 is offline
Vehicle: 2010 DODGE RAM 1500 TRX4
Trim Level: TRX4
Color: BLACK
10TRX41500 is on a distinguished road
Default Trialer Wiring Connector
im trying to ADD another trailer plug to my truck using a trailer wiring adapter it plugs into the existing wiring harness but i cant find the plugs can anyone tell me where there located on a 2010 1500??
Old 05-20-2011, 12:37 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
Don't you have the 4 pin and 7 pin connectors beside the license plate?
If you do, you can buy a 7 pin to 4 pin adapter to use which should give you two 4 pin connections.
What do you need 2 x 4 pin connections for?
Old 05-20-2011, 03:15 PM
10TRX41500's Avatar
Trim Level: TRX4
Color: BLACK
yes i have the OEM connectors but i want to add the extra hookup for a dedicated connection to my led lightbar under the tailgate i dont want to lose the OEM connection. i want to do it the easiest way possible and not have to splice into wires so i figured the plug and play connectors would be the way to go.
Old 05-20-2011, 09:40 PM
dgard61's Avatar
dgard61 dgard61 is offline
Vehicle: 2010 Ram Crew Cab, 4x4 Laramie
Color: Inferno Red/Sandstone
Rep:91
dgard61 will become famous soon enough
From what I read here on the forum the factory trailer 4 and 7 pin can be unplugged from behind the bumper. You plug the adapter into which ever one you want to use. Then plug the the factory plug into the adapter. Sorry for the way I explain thing's. Hope it help's.
Vent Visor's, Bug Deflector, Chrome Fuel Door, Bak Flip G2 Tonneau Cover, Bed Extender, EZ Down Tailgate Dampener, Line X Spray in Box Liner, WeatherTech Winter Mats, Husky Moulded Mud Flaps, Billet Tech Oil Catch Can, 12" S/S Antenna Mast, Chrome T/G Handle, Mopar CAI, Painted Engine Cover, Billet Tech Polished Underhood Cap's, Front Window Tint, Billet Hitch Cover, Anti-Theft Valve Cap's, MGP Caliper Covers, Retractable S/S Stake Pocket Anchors, Mopar Trailer Brake Controller, Recon LED Light Bar, Polished Billet Lock Pins, Mopar S/S Door Sills, Interior LED's, Mopar LED Cargo Bed Lights, Billet Throttle Body Cover
Old 05-21-2011, 03:43 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
with RedRam10.
The factory harness plugs into the back of the factory trailer connector. Your pic looks like that connector, so it would add in the line right at the factory connector.
brad
Interested in one of my mods?
Help Removing Fuel Pump Connector... KenS999 5.2L V8 Specific Topics 2 04-13-2011 08:56 PM
AC wiring jhammer Heating & Cooling 0 02-10-2011 07:45 AM
Which wiring harness is this and where can I find it? hansnfrans Electrical 7 01-20-2011 06:39 PM
Can some one post me a wiring diagram for the C1 connector on the IPM? Tonatom Electrical 5 07-16-2010 07:12 PM
Dash removal/ Heater core replacement Trishafer Heating & Cooling 6 02-25-2010 06:23 PM
