Old 05-20-2011, 09:01 PM
wascobi wascobi is offline
Vehicle: 2010 Ram quad cab
Trim Level: sport
Rep:24
wascobi is on a distinguished road
Default rear end noise
currently at 23k on my june build 2010. about 3k ago I started getting a whine/howl from the rear diff. normally you hear noise in a diff under deceleration. this noise happens under acceleration. wonder if some of those soft chinese axle bearings are in our 2010's as well as 11's?
Old 05-21-2011, 12:07 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Well if it is those bearings then be smart about it pull out the shafts and buy some American made Timken's and of course degrease and repack everything. Change out the differential fluid if you haven't with some Valvoline and some Trans-X Posi-Trac, You don't have to use Valvoline but I think it's the best, I do recommend the Posi-Trac because you have a Hypoid gear and it is required by Dodge to have an additive like this, the Posi-Trac is a replacement for the Chrysler Additive and works great.
Old 05-21-2011, 12:55 AM
Rep:2620
Ummm
i am curious, what supplier made your differential ??
show us some pix & serial numbers
is DANA made in China?
is Spicer ?
are CORPORATE rear ends made by china?
Old 05-21-2011, 02:31 AM
Trim Level: sport
Rep:24
not sure who made it, but its the '10 model with the rubber plug in the cover. in a cost saving exercise the axle bearings were sourced from china.
Old 05-21-2011, 07:57 AM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
I believe I read that there is a factory recall or notice about 2010 rear end problems, might check this forum or contact your dealer
So it is written ! So it shall be done!
Old 05-21-2011, 09:02 AM
Holleywud's Avatar
Holleywud Holleywud is offline
Holleywud is on a distinguished road
Take in to the dealer. Saw a post on the 09 forum about a similar issue. His rear diff seized while driving and broke lots of stuff.
http://www.ramforumz.com/showthread.php?t=50079
Old 05-21-2011, 09:19 AM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
most likely a dana. check on the top of the rear axle for a plate with numbers on it. Also, my 02' has been whining/grinding. Positive it is pinion bearings gone bad, which of course caused my seal to go bad. You can also go to your Stealer and give them your vin and they will tell you what rear end is in it.
Old 05-21-2011, 10:26 AM
ramvan2500's Avatar
Rep:128
Rubber plug is the Chrysler Axle. Their is two different sizes the 9.25 and 8.5. The best way to make sure this is the Chrysler Axle is to take a photo and send it to me and I can tell you for sure. Take a photo of the axle housing at the back, where the plug is, Try to get atleast a picture of half of the housing. Send it to frankcovending@gmail.com If it's Chrysler which I'm sure it is, I can provide you with any torque specs and measurements you would need when removing the shafts.
rattling noise rear end? wickedpissahtruck 2010 Dodge Ram Forum 26 02-11-2014 09:36 PM
Clicking noise in rear end HemiGTX Suspension 3 10-24-2012 02:22 PM
Help With "Whining" Noise From Rear??? GTR0419 5.2L V8 Specific Topics 5 02-07-2011 05:26 AM
97 Ram knocking noise from rear eddie7644 Suspension 4 01-06-2010 11:20 PM
Rear end noise CajunDodge Suspension 1 05-17-2009 04:41 AM
