anti-lok brakes OR master cylinder?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-21-2011, 05:57 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Exclamation anti-lok brakes OR master cylinder??
HI, While working on my truck to resolve 2 problems, a possible 3rd has come up. While twice coming to a stop, my truck slowed down, almost to a complete stop and then the pedal went soft/to the floor. I quickly released my foot and reapplied the brake and all was fine. I looked for fluid leaks, but none. I checked the brake res and full of fluid. How does one determine if this is a master cylinder problem OR as someone suggested to me the 'anti-lok- brake sensors have gone bad. I am not sure how to test either. I am going to plug my laptop into my truck to see if there is a code on the brake system or not. Any thoughts/similar problems and what did you find????
Old 05-21-2011, 06:37 PM
Rep:2962
I would think about air in the brake lines, maybe from a very small hole in the rubber lines or maybe the fluid was low at some time, also you need to check the Booster brake canister hose
wipe off your whole master cylinder, then drive it around, check again for wetness
Old 08-09-2011, 09:40 PM
cabnfevr's Avatar
cabnfevr cabnfevr is offline
Vehicle: 02' RAM 1500 SPORT
Color: blk
cabnfevr is on a distinguished road
If you had air in the sytem your pedal would be spoungie all the time. It sounds like your gettig blowby in your mstercylider. Meaning it's leaking internally. If your abs sensors were bad you would get an abs prk light & you would get speratic vibration in your pedal like the abs was kicking in because of a wet surface stop. I've had both probs before on various vehs not just mopars.
Old 10-02-2011, 11:01 PM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
I agree with Cabn. Sounds like the cups in your master are shot. Once enough pressure has been applied, the rubber moves allowing the brake fluid past. As Cabn said, if it were an ABS issue, you'd have a light or pulsation in the pedal. If it were a leak of any kind, your fluid level would go down. Especially if it happened that fast. I'd be looking at replacing the master.
Old 10-05-2011, 01:58 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Yeah, definitely thinking master cylinder. A failed ABS sensor isn't going to give you those symptoms. Air or a failed master cylinder, as has been stated above, will behave this way.
Old 10-05-2011, 02:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^agree MC, you can rebuild them it's pretty easy.
Sean
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
THIS is how you get better brakes!! weedahoe 5.7L V8 Specific Topics 6 04-01-2011 11:41 AM
Master Cylinder Brake Tubes Recall BlueLightning 2010 Dodge Ram Forum 18 08-27-2010 03:13 PM
Brakes viberate at slower (35mph) stops. steveray Suspension 2 06-05-2010 11:14 AM
