Lower Ball Joint Replacement Help Needed! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-21-2011, 07:48 PM
Ibreak4Change Ibreak4Change is offline
Vehicle: 2002 Dodge Ram 1500 2wd
Ibreak4Change is on a distinguished road
Default Lower Ball Joint Replacement Help Needed!
Hello all. I have a 02 Ram 1500 2wd truck and I'm in the process of replacing worn lower ball joints. But I can't seem to figure out whether these ball joints are the (press in) type or is it replaced by removing the 4 rivet studs on the lower control arm and replacing with a (bolt-in) type.
I have tried the ball joint remover/installer tool from Advanced Auto, Autozone, and now Oreilly's and I have failed to even make the ball joint budge at all. So now I have removed the lower control arm and put it into my shop press and I have still failed to move it all in either direction. Also there is no visible snap ring that I see needs to be removed.
The lower ball joints that I ordered are Moogs and they appear to be the (press in) type. But I noticed that the older Rams like 2001 and older appear to have a bolt-in type ball joint but none seem to be offered for the 2002 and up model. I don't know but I'm at wits end. If anyone has any info or experience on this model if would be greatly appreciated.
Thank you.
Old 05-21-2011, 09:31 PM
Here are some pics if they will help any.
Old 05-22-2011, 07:50 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
If Im not mistaken, those rivets have to be grinded off and the replacements should come with bolts in place of the rivets.
Sure it'll suck, but it'll make you a man
Old 05-22-2011, 08:52 AM
CEM155 CEM155 is offline
Vehicle: 2015 Ram 1500 Express
Rep:22
CEM155 is on a distinguished road
They are supposed to be pressed on as they are sold as a replacement part but, if you ask a Dodge technician at a dealer, even they would recommend to replace the control arm. I've tried in my shop press and couldn't get them to budge either. Technically, you could grind off the rivets but, in my opinion, that would be rigging stuff and I hate doing that. At the end of the day, I just purchased new arms. Probably the most expensive repair I've done to my truck as you can only get the part from a Dodge Dealer. Thankfully, I had a connection at the dealer and paid 10% above their cost. That helped.
Old 05-22-2011, 08:55 AM
Resident Technician
Rep:1915
I'm a Dodge technician at a dealer and the only way I've replaced them was to grind off the rivets and install the new units with bolts. I fail to see how this is any type of "rigging" when the bolts perform the same function as rivets.
Old 05-22-2011, 12:30 PM
Ok thanks for the feedback guys, I thought I was going insane, because I'm using a 20 ton shop press and the control arm ends up flying out of the thing and shooting sparks and I'm wondering why won't this thing budge?? We'll I guess I'll call the dealer Monday and see if their is some kind of replacement kit with bolts. Thanks again guys.
Old 05-23-2011, 02:36 PM
Hey Randy you wouldn't happen to have a part number for that would you? I went to the dealer this morning and the parts guy showed me the ball joint and it looked identical to the one stuck in the control arm except without the little notches on top.
He told me there was no bolt in kit that he knew of and he priced the control arm itself at @ $450 each!!
So I decided to take both lower control arms to a front end specialty shop and even the old man there told me he had never seen that before,(no bolt in kit offered). So he said he will give me a call when they are done, hopefully he gets the moogs in, I'm crossing my fingers otherwise I don't know what else to do except order new lower control arms.
Old 05-24-2011, 07:58 PM
UPDATE---- Got the control arms back from the front end shop this morning. Guy who did the job told me that you have to use an air hammer to knock back the lip on the top of the ball joint. Then he said he just used his "BFH", four pound mallet to knock it out. Then pressed in the new Moog and greased it for me. Hopefully this will help someone who plans on changing their lower ball joints, which they obviously don't last long. The truck maybe nine years old but just hit 43k this month and has sat mostly since it was bought new. I also changed out the upper control arms since the ball joints were rotted and gone also.
So change out lower control arms at @ $450 a piece?? Shiiii, forget that mess. Here's a pic of the new joint.
Old 05-26-2011, 11:39 AM
matt99 matt99 is offline
Rep:20
matt99 is on a distinguished road
whew Im glad you didnt listen to those guys. There are a few different suppliers of the Ball Joints and some have caps and otherr have that nonremoveable cap like yours does. Like your mechanic said, you have to take an air chisel or a good big flathead and knock those indentions off. Then the thing just presses through the lower control arm down. I replaced my lower bjs with Moog, too. 65/each if I remember right.
Now, the upper control arms do have to be replaced as a whole. They are only $110/each I think
[IMG]http://i294.photobucket.com/albums/mm110/swollguy99/1282248743-1.jpg[/IMG]
Murdered
Old 06-14-2011, 06:16 AM
ramstenerson ramstenerson is offline
Vehicle: 2004 Dodge Ram 1500 slt 4x4
ramstenerson is on a distinguished road
I had those same OEM balljoints in my Dodge. Just replaced with moog. Don't need to worry about that cap. I borrowed the balljoint press kit from AAP and just pressed it down through the lower control arm.
3rd gen, lower ball joint
Help with lower ball joint Saugie53 Suspension 2 05-08-2011 04:54 PM
Ball Joint Replacement Questions - 2wd 2500 hangerbum Suspension 2 04-07-2011 10:32 PM
Ball Joint Replacement nocoborn Suspension 9 03-03-2011 07:36 PM
Lower ball joint falling out 98 ram1500 blodge5.2 Suspension 1 10-06-2010 07:47 AM
Lower ball joint issues bruno9 Newbie Checkin! 10 02-13-2010 02:10 AM
