Old 05-22-2011, 04:19 AM
STORMIN503's Avatar
STORMIN503 STORMIN503 is offline
Vehicle: 1995 RAM 2500LD
Trim Level: 2500
Color: Blue-gray
STORMIN503 is on a distinguished road
Default 5.9 Build help
Hi.. I have my 360 tore apart and am forced to bore it out due to a broke ring at just over 100.000 miles .. I would love to raise the compression but am keeping most of the engine stock, for now.. once I get the block back I will no what size pistons to order. 0.30 over witch would bring it to a 365. or a 367 if I have to go 0.40 bore.. but I want to no if anybody has raised the COMP. RATIO just buy changing pistons. I would like to get it to 9.5 to 9.7 but I don't want to have to do the heads just yet.. "that's for the 408 build" I am going with new pistons, rings, all bearings, gaskets, valves ext.. and looking at these pistons and useing them for charting-specs info.. http://www.campbellenterprises.com/mopar_kb_pistons.htm
http://www.campbellenterprises.com/m...ed_pistons.htm
and this is the one I would like to get... http://www.summitracing.com/parts/UEM-KB362-030/
any sugestons on pistons, or getting the comp. up a bit.. or what else I will have to do to put these in my engine.. thanks again
Old 05-22-2011, 07:55 AM
RamTech RamTech is online now
Rep:1845
You're not going to see any great performance gains by just raising the static compression ratio. Since you're going to have the heads apart, you might consider some port work and a different cam grind. If you go with a piston that gets you about 9.5:1, you can level the heads and deck the block and you should be very close to a 10:1 static ratio.
My build sheet... Mopar44064268 Dodge Ram SS/T - Indy 4 06-29-2011 12:29 PM
build dates Guinnessboy 2010 Dodge Ram Forum 3 11-28-2010 09:03 PM
custom enclosure build - 1997 Ram 1500 extra cab Topdown Custom Dodge Ram Interior Modifications - Custom Audio / Video 14 10-25-2010 03:18 PM
Hi, I'm new to the forum and am looking for a build sheet rpsklein Newbie Checkin! 19 08-30-2010 10:38 AM
valve carbin build up mlowney 4.7L PowerTech V8 Specific Topics 0 05-13-2010 01:36 PM
