Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-22-2011, 03:33 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default Something feels wrong after off roading
Not exactly sure what it is I have been battling this for a few months now. Here are some of my symptoms:
1: In turns it feels like the brakes are applied slightly
2: I am getting a rattle from my right front wheel, it gets very bad on bad roads. Driving on hwys I don't get the rattle.
3: I looked under my truck yesterday, the bottom ball joint nut was loose, so I tightened it.
4: I have "minor outer wear" on my front two tires.
5: even with new shocks, it feels like the cab has too much shake on bumpy roads
Some details on my truck: 104,000 miles, OEM Balljoints, New Bilsteins Shocks, New Tires, Balanced and roateded, 4x4 stock height, new outer tie rod ends.
Just give some ideas, I think I should replace my ball joints just to do it since they are old. Sway bar links and inner tie rods.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 05-22-2011, 04:36 PM
Rep:2625
I would suggest going to an alignment shop, a shop that always has old cars being worked on, the alignment shop that i use works on old vehicles, desert trucks, & several gov't type vehicles being worked on, the owner is also a member of a couple car clubs.
Good alignment shops will check out your vehicle for free most times, then they give you a list of things they found that could be issues. Then you decide to get it done or take it back home & do it yourself.
The ball joint being loose would be of concern to me, even if you did tighten it up
the shop that i use, they worked on many of the hot rods in the pix
http://www.truelinewheel.com/default.asp
Old 05-24-2011, 12:19 AM
Rep:1625
OEM Ball joints, Bilstein Struts, Cooper tires, Balanced and rotated, 4x4 stock height, new sway bar end links.
^^^ This is what applies to me on my 07.
Sullivan, please let me know if you get this figured out. I've also got symptoms #1 and 4. My truck is aligned to factory specs, I think that's part of my problem but I'm glad you made this thread.
Old 05-24-2011, 12:54 AM
sullivan's Avatar
Rep:202
I really think it is my ball joints, pisses me off but oh well. I will be ordering new parts in a few weeks and I will let you know how she drives.
Old 05-24-2011, 12:56 AM
Rep:1625
Thanks man, much appreciated.
Old 05-24-2011, 01:00 AM
Try appling the brake pedal slightly when you hear it and see if the rattle your hearing goes away .
Old 05-24-2011, 06:44 PM
sullivan's Avatar
Rep:202
The rattle does go away when the brakes applied.
Old 05-24-2011, 06:47 PM
You may have loose brake pads . Pull the wheels and see if you can move the pads around .
Steering just feels off sullivan Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 04-06-2011 07:56 PM
What's wrong with my truck? jbladedx 4.7L PowerTech V8 Specific Topics 3 03-27-2011 11:08 AM
wrong oil in truck ? nitro1965 Dodge Ram General Discussion 5 01-14-2011 11:23 AM
what went wrong? Ram420 Electrical 2 10-26-2010 05:55 PM
HID help! Something wrong need advice! ScatPak07 Custom Dodge Ram Interior and Exterior Lighting 10 04-10-2010 06:39 PM
