Old 05-23-2011, 12:55 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
Default Dif oil change believe or not?
Went today to Chrysler in Bellevue for oil change, got 16,784 on the clock. So he tells me before the all the checks that the dif oil should be changed and the direction from Dodge is the dif oil should be changed at 15,000. I am in shock as the manual says 100, 000, unless you to towing and any of the other things that will put stress on the truck. So I say check the condition of the oil so the mechanic comes out and shows me the condition of the oil it's pretty clear, [By the way they wanted 120 bucks for the dif change] but claims that they change many vehicles at 15,000 and the oil is black.
So there are two questions as many of you here leave the change till at least 30,000, Have any of you come across this at any Dodge dealers, and do you think that $120 is excessive?
Old 05-23-2011, 01:15 AM
Rep:2616
ok, you have the 4X4
i have the 2X4, they wanted me to change fluids on both the transmission & rear end at 20,000 miles, both are synthetic fluids, i changed at 40,000, maybe i should have changed just before 36,000 warranty period was up, but i was going to use a better product i believe called called Royal Purple.
I suggest that you change both fluids before 36,000 miles because of the new vehicle warranty
Also buy the MAXIMUM CARE EXTENDED WARRANTY before you hit 36,000 miles
It covers your repairs & labor for LIFETIME, on everything that is NOT considered a wear part, like brake parts, fan belts, hoses, & tires
Oil change info needed on a 03 Ram 5.7 zmurphy 5.7L V8 Specific Topics 3 05-27-2011 02:55 AM
Oil change info needed on a 03 Ram 5.7 zmurphy 5.7L V8 Specific Topics 1 05-19-2011 12:32 PM
oil change chrisisbored24 Oil Change 24 05-11-2011 07:43 PM
Anybody Change Their Own Oil??? ND RAM Oil Change 6 05-09-2011 01:47 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 02:00 AM
