Old 05-23-2011, 05:08 AM
swmpsngr swmpsngr is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Laramie- SLT
Color: Red over Gray
swmpsngr is on a distinguished road
Unhappy Spark plugs problems
My number 5 plug is misfiring, I have tried to replace it but the shroud is damaged and I can't get a socket on the plug. the brake booster is so close I don't even have a line of sight to see what the problem is, Does anyone have a solution?
Old 05-23-2011, 12:38 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
when a cylinder is misfiring its not usually the plug its usually something firing the plug so maybe try checking the wire or the cap and rotor or check to see if the plug is wet with gas or oil. if there is liquids in the cylinder you could have a leaking head gasket or consuming oil. could be a number of things, but usually never the plug.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 05-23-2011, 01:21 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:25
Maddevill is on a distinguished road
Talking Plug
Get a little inspection mirror and use that and a flashlight to see what's stuck in the plug area.
Old 06-01-2011, 10:27 PM
Hi guys, thanks for the help, got the plug out of the sleeve and replaced all the plugs with the OEM plug. problem solved, no more miss.
Old 06-05-2011, 07:49 AM
shak01 shak01 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Emerald Green
shak01 is on a distinguished road
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Kevin Sharpe shak@att.net
New Spark Plugs flndrpndr23 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 25 08-10-2013 08:32 PM
Did I not get the memo about spark plugs? Rusty Nib 5.7L V8 Specific Topics 15 04-08-2011 11:32 PM
Spark Plugs?? 2008BIGHORN Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 11 03-27-2011 10:18 AM
8 spark plugs vs. 16 spark plugs Basic Corpse Newbie Checkin! 16 01-04-2011 10:23 PM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
