performance upgrade advice - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-23-2011, 12:51 PM
Rumblyship Rumblyship is offline
Vehicle: 2017 Dodge Ram Crew Cab
Color: Charcoal
Rumblyship is on a distinguished road
Question performance upgrade advice
i want to get a little more power out of my 96 318 with 295xxx KM on it. The truck runs great and i was looking at chips for it to get rid of the deathflash but i don't think i can get one because my diag port won't power on the diag tool so i don't think that a chip would work. Also i was wondering if a CAI would be worth it compared to the stock air box and if so what one would you guys recommend? I have a cheap muffler on it id say it would of been around 100 dollars canadian when it was installed(including labor)(around 100 anyhow), so i am not sure if this is bogging me down or not. Recently replaced one injector, distrib. cap.(and rotor button), all new plugs.
Also i know it is off subject but my fuel guage only goes to 3/4 and when the light comes on it only takes around 48 liters instead of the 96 the tank is suppose to hold so i think the needle is off? or would it be the sending unit busted.
Thanks for any replies in advance.
Old 05-25-2011, 10:09 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 05-25-2011, 10:41 PM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
First, make sure you don't have a blown plenum gasket. Look down the throttle body and see if there's oil in there. If there is, the gasket that is in between the plenum plate and the intake manifold is blown and the intake is sucking oil through. This kit will fix it and prevent future problems as well: http://www.hughesengines.com/Index/p...3&partid=26190
If you do the plenum fix, you might as well do the Kegger mod found here: http://www.ramforumz.com/showthread.php?t=80192
You will have that whole thing opened up anyway, so you might as well clear out some restriction and let the air in better.
Instead of doing the first two mods, and if you want to spend some more money on the intake, you can get this: http://www.hughesengines.com/Index/p...=&partid=24773
This will completely eliminate the plenum problem by replacing the entire intake manifold. You should get some better throttle response and power with this manifold.
Installation guide here: http://www.snowdigger.com/the_garage...es_intake.html
This throttle body mod is free, so give it a shot and maybe add a CAI too: http://www.ramforumz.com/showthread.php?t=46431
For some more serious mods, a set of 1.7:1 Harland Sharp roller rockers is great for adding power. It increases the valve lift. You can find some here: http://www.summitracing.com/parts/CSP-S70037/
And a good installation guide here: http://www.pavementsucks.com/tech-article-32.html
And another one here: http://www.snowdigger.com/the_garage...r_rockers.html
A good set of headers for not too much money: http://www.summitracing.com/parts/SUM-G9045/
Get an SCT Tuner from Hemifever too. It's the best one I am aware of for our 1996 trucks. Get it last because you will need to tell Hemifever which mods you have done. Better to have everything done first rather than have to change a tune later. http://www.hemifevertuning.com/SearchResults.asp?Cat=25
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
Old 05-28-2011, 09:17 AM
Color: Charcoal
thanks for the input i will think about the options that you listed, thanks again.
cai, chip, deathflash, guage, muffler
Hennessey Performance Upgrade Bighert3rd 2011 Dodge Ram Forum 9 01-04-2011 09:57 AM
Poor heater performance - I need advice Fuji Heating & Cooling 3 08-19-2010 07:25 PM
First Performance upgrade? TxHouse Exhaust 9 06-22-2010 11:08 PM
Hurst Performance debuts THE LEGENDARY black & gold COLORs on the Hurst Challenger!! GT Automotive Industry News and Dodge Press Releases 0 03-30-2009 07:56 PM
