Old 05-23-2011, 09:44 PM
DavesRam DavesRam is offline
DavesRam is on a distinguished road
Default MOPAR Running Boards prob
Hey guys,
I have a set of MOPAR boards on my truck. They are the ones that you hang on the pinch welds, then bolt in. The boards are starting to actually work their way out and are loose. They squeak awful too. Anyone else having that problem or have a recommendation on how to make them better? I think the design is awful. Thanks......
Dave
Old 05-25-2011, 10:29 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 05-26-2011, 10:26 AM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Originally Posted by DavesRam View Post
Hey guys,
Dave
I'm not trying to be a wise-ass here, serious question - can you tighten the bolts or are the lugs the bolts run into actually coming loose?
Old 06-06-2011, 03:22 AM
thewagon thewagon is offline
Vehicle: 2010 RAM 1500 QC BigHorn
Rep:35
thewagon is on a distinguished road
I installed an OEM set on my truck and its mounted by inserting threads into the pre-drilled holes underneath the truck. Then you insert the bolts thru the mounting brackets into the threaded inserts.
IF by chance the inserts were installed incorrectly, the bolts will never tighten because the inserts spin.
Try tightening the bolts and see if they cinch down. There should be 6 bolts per running board brackets on the one side.
aluminum running boards liljohn30 Dodge Ram General Discussion 1 10-09-2013 02:35 PM
Aluminum running boards Wayne084 Body & Interior 2 04-10-2011 09:38 PM
Westin SureGrip Running Boards Installed! hckrphil Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 4 11-07-2010 11:37 AM
No Drill running boards? wecoyote 2010 Dodge Ram Forum 13 09-12-2010 02:23 PM
Running Boards Won't Fit (Mopar) dtemp 2009 Dodge Ram Forum 5 06-25-2010 07:24 AM
