Old 05-25-2011, 11:46 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
i knew they did crankshafts but wouldnt that make the camshaft smaller than its sells as? or do they just regrind them to a different size cam?
They grind the cam smaller, but keep the same ratio, all the specs are the same, it is just smaller, you can regrind a cam over and over again (within reason) and keep the same lift/duration, then the actual size difference is made up in the valvetrain adjustment.
and people do sell used cams. I sold a cam I bought for my other truck when I went to a bigger one, it was somewhat difficult to sell though. What are the specs on yours?
Sean
Old 05-25-2011, 12:52 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
a lot of shops can repair, regrind, etc cams. They do it mostly on rare & expensive cams
cams
http://www.google.com/#hl=en&sugexp=...ecc40f3f517c7e
i understand now i just wasnt understanding how they were getting the same lift by grinding material off but i got it now lol.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 05-25-2011, 02:10 PM
Rep:2657
cam shops can even weld on or build up lobes, then they regrind
Old 05-25-2011, 10:56 PM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
hey wut is the specs on that cam? and would you need to change anything with it?
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
Old 05-26-2011, 02:19 PM
soco native's Avatar
soco native soco native is offline
Vehicle: 02 ram 1500 5.9
Trim Level: slt sport package
Color: BLACK
soco native is on a distinguished road
Its a mild street cam acording to hughes and a good super or turbo charger cam. specs are 214 Intake Duration at .050" 218 Exhaust Duration at .050" 114 lobe seperation. the part number is HUG HER1418ALN to see the full specs.
TWIN TURBO IN THE WORKS!!!
Built for boost short block by PIE, forged internals, PIE by JE blower pistons, Edlebrock MAX port heads, PIE turbo cam, Comp Turbos, JGS waste gate and BOV, SCT tuned by PIE and DIY 304 SS sch30 pipe turbo manifolds.
Old 05-26-2011, 02:25 PM
snrusnak's Avatar
Rep:1385
That'd be a pretty good cam for the street, not too radical. You know you have well engineered cam when the exhaust vs. intake lifts and durations are that specifically different...they did their homework. Looks like you can go to 1.6 ratio rockers and pick up alot of extra valve lift as well. I'm surprised for a fairly mild cam it says the ecu needs flashed.
Sean
Old 05-26-2011, 03:25 PM
Trim Level: ss/t
Rep:44
Ya sounds like a good cam wuts the lift. I have 1.7 roller rockers so i think it would be to much for my engine
Old 05-26-2011, 03:31 PM
snrusnak's Avatar
Rep:1385
From their site:
Hydraulic Roller; New Core
Mild street, works well with stock heads, Stage I billet throttle body and headers. 5.2L/5.9L V8 requires computer change. Good super charger camshaft.
VIEW OUR CAMSHAFT F.A.Q. PAGE.
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .487"
.510"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .520"
.544"
Exhaust Duration at .050" 214
218
Lobe Separation Angle 114
Intake Opening at .050"
Exhaust Opening at .050" -4 BTC
46 BBC
Intake Closing at .050"
Exhaust Closing at .050" 38 ABC
-8 ATC
Min. Suggested Cylinder PSI 165
Sweet Spot RPM 2300 - 6100
Sean
Old 05-26-2011, 03:33 PM
snrusnak's Avatar
Rep:1385
Sorry that got messed up but you can figure it out, the intake will have the smaller lift. I think 1.7 rockers would be up over .6" of lift, or close to it anyway, and probably couldn't run that, that is ALOT lol. Duration is more desirable for power.
Sean
Old 05-26-2011, 03:56 PM
Trim Level: ss/t
Rep:44
Wow def way bigger than i want to go. I want a max of 480 that will wrk with my 1.7 rr
4.7 Comp Cams lakers676767 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 2 09-05-2009 11:44 PM
Cams for the 4.7 sniperstud1721 Newbie Checkin! 8 08-24-2009 02:38 PM
Do tonneau covers make people curious or keep them out? Ramblerman Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 17 07-25-2009 12:38 PM
Stupid people csurane24 Off Topic Discussion 7 04-30-2009 10:36 AM
looking into cams???????????? ph3nom3non03 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 0 12-24-2008 07:19 PM
