Old 05-24-2011, 06:06 PM
CJzonin CJzonin is offline
CJzonin is on a distinguished road
Default Cylander 8 Misfire
I have a 99 1500 5.9 ram sport with a terrible misfire. My scanner always says its cylander 8, Ive replaced the plugs, wires, the cap and rotor and the intake plenum gasket. At idle the truck shutters, but some days are much worse than others and some days you can hardly tell. Could it be an injector or the cat maybe?
Old 05-24-2011, 06:23 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
or a head gasket hopefully not!
-PAT-
Old 05-25-2011, 06:44 AM
Rumblyship Rumblyship is offline
Vehicle: 1996 Dodge Ram 1500 ClubCab
Trim Level: Larmie SLT
Color: Green
Rumblyship is on a distinguished road
my 5.2 did this when one of the injectors were clogged, would cause CEL and the truck to shake under low rpm but was fixed when a new injector was put in.
Old 06-01-2011, 10:42 PM
swmpsngr swmpsngr is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: Laramie- SLT
Color: Red over Gray
swmpsngr is on a distinguished road
Could it be that your using E-3 Spark plugs?? My 2001 had the same problem only on #7. Plugs were less than 6 months old. Went back to Champion OEM plugs and problem was gone.
Old 06-01-2011, 11:16 PM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
I would make sure the spark plug wires are all tight on the fittings. Run some Techron injector cleaner through the tank and see if that helps. It's not as good at cleaning the injectors as pulling them out and cleaning them by hand, but it might help.
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
Old 06-05-2011, 06:24 AM
shak01 shak01 is offline
Color: Emerald Green
shak01 is on a distinguished road
If you recently put new plug wires on,
Here's a TSB that discusses wire routing and at least some of your symptoms:
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Pay particular attention to the warning about plug/coil wire(s) crossing only at right angles and notice how close the coil wire is to the #8 wire where the two wires come away from the dizzy cap! Notice how the coil wire is routed straight down the side of the distributor with the #8 wire crossing it at a right angle. Same deal where #8 connects to the plug and crosses the #6 plug wire.
According to the TSB:
"This rerouting procedure should be performed before any other misfire, surge, or spark knock repairs are attempted."
Kevin Sharpe shak@att.net
multiple misfire at idle and under acceleration nick2889 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 10 08-18-2011 11:25 AM
Cylinder 5 misfire, and now cylinder 8 and a random misfire... suggestions? itsaRAMthing 5.9L V8 Specific Topics 5 06-05-2011 07:35 AM
Help!Random Misfire 03BlueRam 3.7L PowerTech V6 Specific Topics 3 12-30-2010 05:43 PM
5.9 misfire problem jcasey10 5.9L V8 Specific Topics 16 08-30-2010 11:43 PM
Random Misfire and Cyl 8 Misfire jabyrum 2009 Dodge Ram Forum 11 08-20-2010 05:39 PM
