Old 05-20-2011, 02:49 AM
ocl ocl is offline
Vehicle: 03 dodge ram
ocl is on a distinguished road
Default HELP!!! ac 03 ram
ac compressor clutch kicks in when it wants to, pulled a vac right amount of freon came out . i also swapped relays with a spare one, took out relay made two pocket screw drivers touch eachother clutch kicked right in. fuse is good.
Old 05-21-2011, 05:04 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Maybe I don't understand what you mean....but from your description, it sounds like it's functioning normal. The AC compressor will kick in/out based on what the system computer wants.
Are you saying the AC doesn't work?....
brad
Interested in one of my mods?
Old 05-24-2011, 01:02 AM
ocl ocl is offline
sometimes it will blow cold when it doesnt the ac clutch aint coming on at all only hot air comes out.
Old 05-24-2011, 01:14 AM
mbehlok's Avatar
mbehlok mbehlok is offline
Vehicle: 2007 Dodge Ram QC Hemi
Rep:39
mbehlok is on a distinguished road
There should be a pressure switch for the AC system.. Maybe that is faulty and causing the system to think that there is not enough Freon pressure. That switch is what allows the compressor to kick on when the computer tells it to..
Should be easy to replace and fairly inespensive. I believe there is a valve under the switch, so you can unscrew it without losing any freon..
Hope that helps
K&N CAI, Magnaflow Custom Exhaust, DS Predator CROM 09r11 93 Octane tune W/O MDS, 10" Rockford Fosgate Sub, Kenwood amp
Old 05-24-2011, 01:15 AM
mbehlok's Avatar
Rep:39
oh, normally the switch has 2 wires coming in and it usually attaches directly to the AC lines or maybe the compressor itself..
Old 05-24-2011, 02:37 AM
brad12kx's Avatar
Rep:2581
with mbehlok. The pressure switch could be the issue if the system is charged correctly.
brad
Old 05-25-2011, 02:59 AM
ocl ocl is offline
thanks abunch i will try that. thank god its been working for the past week hope i dont jinx it.
