Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-21-2011, 08:33 AM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Question New tranny pan gasket rtv y/n?
I just bought a new OEM tranny oil pan + the gasket. This gasket is hard plastic with something similar to small O-ring material weaved all around on it on both sides. Is RTV still used? OR is this gasket design good enough?
Old 05-21-2011, 10:57 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Your not suppose to use RTV for the transmission. Never use it for the oil pan. The regular cork or rubber gasket is perfectly fine. Torque the bolts to 13 ft/lbs or if you don't have a wrench in ft/lbs then torque to 156 in/lbs
Be sure to go around the bolts on the pan after torquing to make sure they are torqued properly.
But yea never use RTV. It's not a good idea.
Old 05-21-2011, 05:43 PM
Trim Level: LT
Color: almond
Rep:19
Exclamation gasket/torque
Hi, thx for the response. When I removed the original pan, I found it had an identical gasket that I bought with the new pan. Unknown to me, these gaskets can be re-used. So I now have an extra. My Chiltons list 2 trannys for this truck and I don't know which I have. 1 says 105"/lbs and 1 uses 125"/lbs of torque on the tranny pan bolts. I chose the lesser of the 2 and will keep an eye on it. I changed the filter while I had it open. I found a small piece of metal on the magnet and I'm not sure what it is. About 1/16" thick and it is obviously broken from a larger piece. It looks like a partial 'arch' like it is a piece of a 3/16" wide washer for lack of a better description.
Old 05-21-2011, 09:04 PM
ramvan2500's Avatar
Rep:128
No washer's that I know of in tranys. I wouldn't worry about it. Yea just don't ever use RTV. I wouldn't of reused that gasket, I would just replace it don't be cheap. It would suck to leak trany fluid while driving! What ever the chilton says I guess ok, I go usually by what I am supplied by Chrysler.
Intake Belly Pan Gasket RamTech Dodge Ram Knowledge Base 3 02-27-2015 02:30 PM
03' Dodge Ram 1500 4.7L Magnum - TRANNY PROBLEM - Did the shop screw my tranny up? emodpro 4.7L PowerTech V8 Specific Topics 3 09-16-2010 02:53 PM
New tranny and eng. t-stat, but odd temp behavior glostamann 5.2L V8 Specific Topics 1 03-13-2010 02:08 PM
Quick tranny question Excoastie 5.7L (345 cu in) HEMI V8 Specific Topics 4 02-28-2010 03:31 PM
No reverse in tranny YoMoma 5.9L V8 Specific Topics 16 12-08-2009 10:55 PM
