Old 05-24-2011, 10:42 PM
Hermosa Hermosa is offline
Vehicle: 2007 Dodge Ram Sport
Hermosa is on a distinguished road
Default How can I tell if I have all the parts for Sirius radio?
Hi all, I hope I'm posting this in the correct area. I'm new, this is my 2nd Dodge...I just couldn't stay away! I picked up a really clean 2007 Ram 1500 Sport, and I can't fully tell if it's setup for Sirius. The radio is the REF model, and I was able to pull the ESN/SID code, and it has the antenna on the rear roof. How can I find where the Sirius module is located. I assume if that there, I'm in business.
Thanks for your help, I'm looking forward to reading a lot of posts here over the long weekend. Thanks in advance.
Hermosa
Old 05-24-2011, 10:59 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
Sounds like your good to go ...i dont think the 2007 came sirius ready. It needed to be installed by the user. I have the starmate which came with the radio itself mounting dock and antenna and power cable. If the previous owner had used an aftermarket deck or even the stock deck you would need something like this
http://shop.sirius.ca/edealinv/servl...rLangISO=en_US
I would first trace the antenna wire and see where it goes you may find exactly that and if you have the SID# you should be golden. If not that kit is cheap and the sportster kit you can find for under 90$ its the best investement ive made for my truck so for i would say.
Hope this helps if not theres plenty of experts on the Z
Old 05-25-2011, 04:15 AM
Rep:2657
I am not sure, but i believe it would be located at the rear of the radio, it has to plug into some where
here is a site that makes reference to it & a kit that you can buy if you don't already have it
http://www.jimsautoparts.com/mopar_p...lectronics.htm
you might be able to cross reference it to installer.com or crutchfield.com products
Old 05-25-2011, 06:06 AM
dksram's Avatar
dksram dksram is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Rep:27
dksram is on a distinguished road
If you pulled an esn from the radio then it's ready to go. My 07 has it already plugged into and built into the trucks Factory Radio.......
No need in ripping things apart.
Old 05-25-2011, 09:24 AM
Thanks for all the help, I think I have a few things to look for tonight. I did a search on the site last night, and was surprised there was so many threads about Sirius radio... so sorry for starting a new thread. From what I have read, I need to check a few things, and I'll keep you posted to what I find.
thank you!
Hermosa
Old 05-27-2011, 09:34 AM
Just a quick update. I was able to get the Sirius activated, I had the Sirius module installed under the dash (located above the glove compartment).
I was able to find the info I needed from searching in this site, lots of great info here. thanks again.
Hermosa
Old 05-27-2011, 12:16 PM
Glad to hear that worked out for ya! I'm sure I have the module as well but I didn't activate Sirius.
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 12:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 10:44 PM
Change stereo radio frequencies? Tentman Electrical 10 01-17-2010 04:24 PM
2009 Factory Radio Guide RamTech Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 12-21-2009 02:55 PM
