4th gen regular cab lift pics - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 05-25-2011, 10:01 AM
hotcornernoprob hotcornernoprob is offline
Vehicle: 2011 Dodge Ram 4X4
hotcornernoprob is on a distinguished road
Default 4th gen regular cab lift pics
i have a 2011 Ram 1500 regular cab 4X4. Anyone have pics of this truck w/ a 4 or 6 inch lift? I've seen quad and crew pics but am looking for regular cab pics. Also trying to get an idea on which size wheels to get. Thanks
Old 05-25-2011, 10:16 AM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
I can help you out
Although I lowered my RCSB 4x4 (Ground Force 2/3 drop)
I did snap some shots at the dealers lot where they had my Ram's twin lifted (Mopar 4") on 35's
Old 05-25-2011, 03:04 PM
awesome pics!! thanks for reply
Old 05-25-2011, 05:02 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
Wow they let you do a whole photo shoot with that truck nice!
Old 05-25-2011, 05:47 PM
Rep:561
LOL!
I test drove it too
Hated the ride, the handling, the loss of power.
I bet the fuel economy would suck too, Seriously needs a re-gear to 4.56's with 35" rubber.
I could drive circles around it with mine. Literally!
You can see further down the road though
and it does look pretty good for a 4" lift
shame they didn't make a better tire/wheel choice
If I ever get tired of rippin' up the drag strip with my 4x4 and get the urge to build a tall trail rig again,
I'll trade my Drag Radials for some Toyo M/T's and swap them onto my Moto Metal 951 drag rims
these would look So much better on that truck
My last Trail Rig was pretty bad @ss :
Old 05-30-2011, 08:23 PM
tbeaton tbeaton is offline
Vehicle: 11 2500 4x4
Rep:14
tbeaton is on a distinguished road
4.56 gears would make the gas mileage even worse. i know at least one guy with a power wagon and 4.56 with a lift and he gets like 10 mpg tops with his. any idea what was in that truck for gears? 4.10 would probably do the job.
11 deep water blue 2500 big horn, 5.7 hemi, 4.10 gears, 6" bds short arm lift, 20x9 -12 offset kmc hoss black wheels, 37x12.5x20 nitto trails, n fab cab length nerf bars, banks muffler w/ lou's custom tubing, pocket flares, top gun customz dual steering stabilizer, mission sled deck.
Old 05-31-2011, 10:44 AM
Rep:561
LOL! a Power Wagon is a TANK!, about 1000lbs more than my Ram
Going from a 3.92 to a 4.56 ratio and from a 33" to a 35" will be about 200 rpm's more at 65 mph.
The final drive ratio in overdrive in the 545RFE is only 0.67:1
That's good enough to keep RPMs around 2K with 35's at 65MPH
Lifts and Larger Heavier M/T tires eat away at fuel economy, not lower (higher numerically) gears.
Old 05-31-2011, 10:58 AM
Rep:561
IMHO 3.92/4.10 gears work just "okay" for stock 33's on a 4800lb RCSB 2WD R/T
...but I think a 5700lb Quad Cab 4x4 needs 4.56's especially for 35" tires, and even more so if it ever has to haul or tow anything.
The Ram 5 speed auto 545RFE ratio's
1st 3.00:1
2nd 1.67:1
2nd Prime 1.50:1
3rd 1.00:1
4th 0.75:1
5th 0.67:1
We have TWO overdrive gears, but you wont use them properly if you dont re-gear your axles to return the truck to its optimum rpm range.
The 0.67:1 overdrive is more than enough to bring the rev's with 35's/4.56's down to almost the same a Ram with 3.92/4.10's and 33's
33/35= .9428 X 4.56 =4.30:1 net effective gear ratio
If you think that's too high, then consider the added weight of an M/T tire is substantially more than a Goodyear HP.
The increase in rotational mass plays a factor too, as does the added drag of the tread design.
FYI, a 37" Nitto Trail Grappler weighs the same (without Wheel!) as the stock Goodyear 275/60R20 does mounted on a stock 20" wheel.
...not to mention the increased negative effects on aerodynamics after lifting a Truck 4"-6".
Check out this chart for ideal RPM's based on 65 mph with a 1:1 gear ratio:
http://www.4wheelparts.com/aux_incl/gear_ratio.html
Now consider that the Final Drive in 4th is 0.75:1
Rev's with 4.56's and 35" tires at 65 mph = 2134, in 5th = 1906
Here's an online calculator
the one nearest the bottom allows you to input the final drive ratio
http://www.csgnetwork.com/multirpmcalc.html
I've been lifting trucks, swapping tires and gears since the early 80's , Re- Gearing doesn't kill fuel economy, Lifting and Putting Larger Mud Tires does...I've done it all a dozen times over.
My RCSB 4x4 is lowered and running 305/50R20 Grapples...about 32"x12" and I'm swapping my 3.55's for 4.56's.
I have a dedicated set of smaller 27" Drag Radials that give me an effective ratio of 4.30:1, the EVIC still reads 20 mpg at 65MPH/2000rpm
(Tire Size corrected with Diablo, speedo verified by hand held GPS)
My best economy with 3.55's pushing my heavy Grapplers is around 22 mpg on flat level ground
but if I get into some hills the engine lugs and has to constantly gear down and drop out of MDS....so MPG can actually be worse long range.
Going from 3.55's to 4.56's only changes the rpm's by about 400 with the same tire,
Old 05-31-2011, 11:32 AM
Rep:14
agreed, and i know that the power wagon is a heavier vehicle but 4.56 gears just don't seem to be a streetable gear. nice jeep by the way.
Old 05-31-2011, 12:40 PM
Rep:561
This seems to be a huge mis-conception on this forum
It's the BEST possible gear and very street able for 35" tires
You have to experience it to realize the RPM range changes favorably
especially with our overdrive Transmission, making it an excellent choice, City or Highway!
Dont Fear the Gear!
its all about the optimum RPM range and staying in the powerband. With a 0.67 final drive
swapping 3.55's to 4.56's can only make a 200 rpm difference at 65 MPH when going from 33" - 35" tires
How is that less streetable?
If you dont run a 4.56 gear with 35's+
this is how you negatively effect an already weak tranny:
Stock 545RFE Gearing ...Basically 3 drive gears, 2 overdrives
(2nd Prime is your kick down passing gear at 1.50:1)
1st 3.00:1
2nd 1.67:1
3rd 1.00:1
4th 0.75:1
5th 0.67:1
when you add a tire +/- 10% larger without re-gearing
you end up with this mess...
1st 2.70:1
2nd 1.50:1
3rd 0.90:1
4th 0.67:1
5th 0.60:1
2 Drive gears with 3 overdrives
although You pretty much lose 5th gear, unless you're going down hill or have a tailwind pushing your lifted rig with heavy 35" M/Ts
You also have an under geared 1st, and a 2nd gear that gets the bulk of the work ...why?
Because 3rd, 4th and 5th are all overdrive gears now (read less than a 1:1 ratio)
Tundra's are available stock with a 6 speed trans, and 4.30:1 axle ratio's
IMHO, Dodge shouldnt be using anything less than 4.10's for Rams with heavy 20" wheels.
In 2012 the Ram's are getting a new 65RFE 6 Speed Auto,
and a new 3.99:1 axle ratio to replace the 3.55/3.92/4.10
Source: http://www.allpar.com/news/index.php...sions-for-2012
The 68RFE gear ratios are:
1st 3.23:1
2nd 1.83:1
3rd 1.41:1
4th 1.00:1
5th 0.81:1
6th 0.62:1
I guess the 8 speed has been back burner'd but this is still better than the tired old 5pd auto that's a decade + old now
A shop "forcing" me to put 20's on my lift? Boblawbla Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 19 04-30-2011 12:49 AM
Can I get pics of the 5" PA lift installed? sinistersix Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 47 03-22-2011 08:48 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
2" lift on my '05 tomorrow, what should I expect Pursuit Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 01-30-2011 11:07 PM
How to Do a Lift Properly RootBeer Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 07-29-2010 12:50 PM
