Old 05-25-2011, 11:38 AM
Laffs Laffs is offline
Vehicle: 2006 Dodge Ram 1500 4x4
Rep:39
Laffs is on a distinguished road
Default Leveling Kit Measurement Q?
Ok. So my truck was sold to me as having a Truxxx Leveling kit installed (2''). It also has 285/65/20 BFG's (34.5) on it.
Lately I've been noticing more and more that the truck still isnt "level" and the back end is still slightly higher in the rear.
Is this normal? I thought with the leveling kit the front end would be even with the back? Any one know what my front fender height would be or should be?
Heres a (terrible) pic for reference
Reason I ask it
- I Like knowing exactly whats been done to my truck
- I'm planning on getting a set of 35x12 or 295/65/20s in the future, if its not leveled or something is not where it should be I want to know so I can order the appropriate parts to clear.
Thanks
Old 05-26-2011, 12:33 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
I've read different posts and depending on the kit some posts indicate ther is still a unlevel latitude. Your truck looks great as it sits now!
Old 05-26-2011, 04:44 AM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
you'll never get a "perfect" level....you'll either be a little higher in the front or back...preferably the back if you tow/haul anything. Trucks that are used as trucks will always have a rake.
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT Stock
Old 05-26-2011, 05:24 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Nothing wrong with a little rake .
Old 05-26-2011, 10:23 AM
Rep:39
Yea, I was just worried about it clearing the full on 35's. Guess I'll find out when that time comes.
Old 05-26-2011, 04:23 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Easiest way to tell is to look at the top of the coil over and see if there is a spacer there or nor
Old 05-26-2011, 07:59 PM
You could add a small spacer to the front at the top of the coil.
I think your truck looks good as-is! Not sure you are gonna clear 35's with only a level kit but it won't hurt to try!
Old 05-26-2011, 11:35 PM
brooxie brooxie is offline
Vehicle: 2011 ram 1500 quad cab
Color: Mineral Gray
Rep:15
brooxie is on a distinguished road
i got 2.5 up front and 1.5 in the rear. guy at the shop was originally going to give me just 2.5 in the front and told me it would level me right out but there wouldnt be any rake. i still use my truck as a truck though so i put the 1.5 in the rear to give me some rake for pulling a trailer etc. with 2.5 up front i got 35/12.5/17's on. my rims are a -20 offset and i have zero rub, it is pretty tight though. not sure if that .5 inch will make a difference for you. although with the -20 offset rims i had to put some spacers in. the inside wall of the tire was sitting real close to the upper "a" arm. spacers scare me though so im already pricing out some rims with a -18 offset so i can lose the spacers.
Old 05-27-2011, 12:20 PM
Rep:39
Yea there is a small rubber spacer on top of my coil spring, guess thats my leveling kit, I finally went and looked (hard to see, had to crank wheel and lay on ground). I'm ok with the unlevel look as i do plan on towing with it.
I'm going to run a 295/65/20 Nitto Trail Grappler MT, so tall as a 35 but a bit narrower so hopefully that lets me clear it. Wheels are 20x9 with a +15mm offset.
Will post pictures once I buy the tires might have to wait, just bought tow mirrors, cab lights, and am having the front grill painted to match along with have my bumpers touched up. Then I plan on painted my headlight inners.
I bought this truck to be the daily driver and tow rig for the mustang......and now I'm modding it out...
leveling kit....help? dodgeramkid290 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 03-26-2011 04:21 AM
HBS leveling kit installed BiggBerger Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 02-07-2011 02:04 PM
2WD Leveling Question bigedschukar Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 20 11-18-2010 09:20 PM
Quoted $1373.50 for alignment after Installing Leveling Kit doozy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 11-01-2010 11:20 PM
Need help with newly installed leveling kit! PLEASE! Who Dat Ram 2010 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 06-04-2010 10:36 PM
