Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-25-2011, 11:23 AM
ddenton ddenton is offline
Vehicle: 2002 Dodge Ram QC SLT Sport
Trim Level: SLT Sport
ddenton is on a distinguished road
Default Limited Slip question
I have a 2002 Ram 1500 QC 4x4. It's equipped with the 20" wheels and the 3:92 gear (with Limited Slip).. I notice that when I first get in the truck and when I backing and turning at the same time I feel something like little jerks. It's very light and I believe its must the limited slip. Would you all agree?
Thanks!
Old 05-25-2011, 11:28 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Could be, have you kept up with the rear end services? I want to say it's every 15-20k miles? There is also a special additive that goes with the fluid I believe, someone with more knowledge may chime in, or look at the service manual....if you haven't kept up with them the fluid may be no good.
Sean
Old 05-25-2011, 12:23 PM
I just bought the truck and I'm just noticing little things and may or may not be normal. The last owner changed the rear diff. oil around 25,000 miles ago. He said he put Lucas synthetic gear oil with the SL additive.
Old 05-25-2011, 12:29 PM
snrusnak's Avatar
Rep:1385
I've never had a lsd, so have little experience, but it sounds like its due for another change, especially if the guy was burning rubber alot. At least try checking the fluid level...and when you do try and pay attention to see if the fluid smells burnt, if so I'd change it. Remember the lsd is a clutch pack, it could be worn out as well, and the fluid is very important also. All that being said, hopefully someone with more knowledge on lsd will chime in.
Sean
Old 05-25-2011, 12:45 PM
This truck has 85,000 miles on it and is a cream puff. I dought it's seen much rubber burning. Thanks
My Build Sheet, Do I have Limited Slip Diff al2ride 4.7L PowerTech V8 Specific Topics 7 11-03-2011 10:35 PM
Question about switching to limited slip dif wedgeheaded Dodge Ram General Discussion 1 01-23-2011 09:03 AM
Limited slip question.. Turbovsix 2010 Dodge Ram Forum 31 08-30-2010 05:14 PM
Limited slip trluby Newbie Checkin! 9 01-26-2010 09:46 PM
Aftermarket Limited Slip Mike Maples 2009 Dodge Ram Forum 0 07-22-2009 04:44 PM
