Old 05-25-2011, 11:57 AM
daleoregon daleoregon is offline
Vehicle: 2011 Dodge RAM 1500
Trim Level: SLT Big Horn Edition
daleoregon is on a distinguished road
Default Painting wheel flares - where & cost
I have a new 2011 RAM 1500. I would like to add the OEM fender flares. I found a video showing the install and that looks fairly easy.
The truck is white so I'm guessing I would paint to match. The parts site states "Mineral Grey with a medium grained textured finish (can be painted)...". Sounds as if the flares need to be sanded before painting.
Anyone had these painted? Where was this done? Just your corner body shop? And what was the cost to do this. Seems like a pretty small job where set-up costs would dominate.
I also want to add the heavy duty splash guards. They sell two types, for trucks with or without fender flares. Has anyone installed the splash guards along with fender flares? If so, is the installation order important?
2011 RAM 1500 Quad Cab 5.7 Hemi 4X4 with Canopy & Bed Slide
Old 05-25-2011, 01:00 PM
Rep:2657
I went with a set of Bushwackers after looking at the ones from Dodge/Mopar
mostly because the Mopar flares that they could order were for Rams with a metal bumper, mine has the plastic front bumper
I put the original mudflaps back on over the flares, the molded ones were not out yet when i did mine & i don't think you can use molded flaps with flares
On the '11 you may find a plastic piece on the bottom of the sheet metal at the back of each tire, i believe they have to be removed, but, i'm not sure
I also have plastic wheel well covers front & rear, makes it easy to clean under there
[IMG]
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Wheel flares for 2010 2500? WILDMAN 2010 Dodge Ram Forum 1 05-14-2011 11:14 PM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 10:40 PM
wheel flares and mud guards flip16 2010 Dodge Ram Forum 9 01-31-2011 07:13 PM
Painting fender flares pmcaree19 2010 Dodge Ram Forum 17 01-09-2011 10:56 AM
