Old 05-25-2011, 04:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Default Ball mount selection
I'm not new to towing, but am new to buying a ball mount, I've always towed with other peoples vehicles, or my vehicles already had everything setup. I need to buy a ball mount and am trying to figure out what drop/rise I need, and I know it depends on trailer height, but was hoping some of you experts could help me with a general range based on the standard open lawn equipment trailer type stuff. My truck is stock ride height, but I may drop it about an inch or two in the future, if that matters. I have a curt class IV receiver, I know it's overkill for my truck, but I'd rather have something a little beefier than at it's limit, and I want a ball mount that I could tow 8,000lb with if I ever change my gears(the way my truck is currently setup I am rated for 6,250). Again, I'd just rather have the heavier duty one. Any suggestions please I need this fairly soon and only want to buy it once! Thank you.
Sean
Old 05-25-2011, 04:43 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
They make one that allows you to change the height by removing one bolt and moving it to the desired level.
Old 05-25-2011, 04:53 PM
snrusnak's Avatar
Rep:1385
Is that the type that has the notches? Are they rated to tow as much as the others? I've only looked at walmart and don't know where else I can look, I'm really looking for convenience, rather than hunting down a trailer place and spending alot of time figuring out what to get. I'll probably need this in about 2 weeks.
Sean
Old 05-25-2011, 04:55 PM
I'd go look at UHaul's website or a UHaul near you. Also, check in with some RV dealers in your area. Both of those sources have everything you need.
Old 05-25-2011, 05:25 PM
snrusnak's Avatar
Rep:1385
Thanks...I looked at the adjustable ones that are aluminum and have the notches, wow they are like $200! That's more than I paid for the hitch! I'm thinking I'll prob need a 2" drop, and I found an aluminum forged/1 piece one on ebay for about $40...I may try Uhaul tomorrow evening.
Sean
Old 05-25-2011, 05:39 PM
Rep:2625
check out this site, i have found it very helpful
http://www.etrailer.com/
Old 05-25-2011, 11:37 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
There are different types of ball mounts. Some are "tube type" which should be used for light duty stuff. Others are "solid" and they are used to pull much heavier stuff. Also a good rule of thumb is that from the top of the ball to the ground should be app. 18". This is only a guide line. Make sure your trailer is level when it is hook-up.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Lower Ball Joint Replacement Help Needed! Ibreak4Change Suspension 13 09-05-2014 12:57 AM
Where did you mount your antenna? Ramathorne 2010 Dodge Ram Forum 10 02-22-2011 02:44 PM
Death wobble = axle swap fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-08-2010 11:50 PM
Lower ball joint falling out 98 ram1500 blodge5.2 Suspension 1 10-06-2010 08:47 AM
Ball joints black beauty Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 5 03-11-2010 06:39 PM
