Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 05-25-2011, 10:37 PM
moose3 moose3 is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew w/Rambox
Color: Deep Cherry Red
Rep:36
moose3 is on a distinguished road
Default Hardwired Radar Detector: How to
Well after my truck spent a week at the dealership with its reworking, my radar detector installed gained some interest.
So I would thought I would pass on to all just how easy it is. But if you aren't sure what you are doing I could see why it would be intimidating.
1. Mount radar detector where you like it to live, I like mine tucked up nice and tight, with just enough room to access the buttons on top.
2. Cut the cord off with enough length to make it to the passenger side of the RVM (rear view mirror).
3. You will need a small spade terminal, when I first did this mod years ago on a different truck I used a crimp on fork spade terminal and cut one of the forks off, so I had a single pronge. It works, and if that is what you have available you can use it, but it a little thick, so getting it wedged in beside the terminals is tough. I since have gone to using a small length of solid core wire. You could attach this to the stock cord using solder or a crimp on butt connector. Then I take I strip about a 1/2 inch on the end and hit it with a hammer flattening it out nicely. So you end up with compact, very thin terminal that will wedge in perfectly to the OEM connector.
4. Open the little door on the back of the mirror to access the connector, you need one that is keyed on and a ground. On my 2011, keyed on is the pink with green tracer, 4th wire in from the right/bottom top row. Ground is the wire farthest to the right/bottom bottom row.
5. Close up the access door, and tape new wires to RVM wiring loom, so if the detector falls off windshield, which it certainly will, it won't rip out the wires.
Enjoy, wires on the dash are for the novice and kids.
Old 05-26-2011, 12:00 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Nice post and helpful too!
Old 05-26-2011, 09:13 AM
gingrbredman's Avatar
gingrbredman gingrbredman is offline
Vehicle: 2011 Ram 1500 Crew Sport
Color: Deepwater Blue
Rep:89
gingrbredman will become famous soon enough
Nice info. I was looking around here a while for that info before I came across it, to also install a hard wired radar detector. Thanks for posting that here so it can be easily found later for others.
What is that accessory you have hanging from the mirror?
Gusz 2011 RAM SPORT CC -Lockpick CHR550 -Hardwired Radar Detector - Custom Trailer Cam - -Fold a-Cover G4 - Bed Rug - Billet Shifter - Debadged - 18" Magnaflow - Custom Clear HID Projectors - LED Tailgate Bar - Custom Billet Badges -
Old 05-26-2011, 10:42 AM
Actionjackson's Avatar
Actionjackson Actionjackson is offline
Vehicle: 2013
Trim Level: EXPRESS
Color: WHITE
Actionjackson is on a distinguished road
I wondered why when they broke in my truck they stole my escort.I didn't have it hard wired but they took the clip ofc the back of the mirror.my point is they must of thought it was hard wired and knowed what they was doing and looking for......sorry to jack your thread but after seeing that it made me think.
Old 05-26-2011, 12:23 PM
Vehicle: 2011 Ram
Rep:36
Just a little garter action, helps blend it in. And helps the wife feel the love.
Old 05-26-2011, 05:36 PM
FireWire's Avatar
FireWire FireWire is offline
Vehicle: 2011 Dodge Ram
Rep:12
FireWire is on a distinguished road
Great idea!
I am going to use this idea for another application.
I am a volunteer firefighter. This would work great for powering the emergency light in my truck.
Right now I have a wire going across the headliner, tucked in behind the trim on the A pillar, under the dash, and then plugged into the accessory plug in the console.
I would do this for a radar detector, but sadly, they are illegal here.
Jeff
Old 05-31-2011, 06:22 PM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
Great idea!! Did you have to cut or drill a small hole in the access door on the back of the mirror for the wires?
Old 05-31-2011, 09:53 PM
Vehicle: 2011 Ram
Rep:36
No drilling needed.
Old 05-04-2012, 04:02 PM
sjsleuth sjsleuth is offline
Vehicle: 2011 Ram 1500 Big Horn
Color: blue pearl
sjsleuth is on a distinguished road
Thanks for the info. Just did this but it took about an hour. Just couldn't get that spade in the plug. Smashed the spade with a hammer to flatten it then it went right in. Love it no drilling. Should have taken me 15 minutes...
Old 05-04-2012, 05:39 PM
Captc Captc is offline
Vehicle: 2012 Dodge Ram
Color: Red Pearl
Rep:23
Captc is on a distinguished road
Check this mount out. BlendMount 2000 Series Mount for Beltronics / Escort radar detector. Goes on back of mirror. I used a telco cable to connect to mirror power.
Captc
Hardwired Radar Detector KwikStix Custom Dodge Ram Interior Modifications - Custom Audio / Video 17 01-19-2012 05:36 PM
Escort passport x50 radar Actionjackson Miscellaneous For Sale 4 04-21-2011 12:36 AM
Direct Wiring A Radar Detector Quiet Lunatic Electrical 10 07-19-2010 10:59 PM
Chrysler and the Radar - part I 1970 Charger Automotive Industry News and Dodge Press Releases 1 04-19-2010 07:53 AM
09 radar hardwire cameron1507 Electrical 3 04-09-2009 10:21 PM
