Old 05-25-2011, 10:49 PM
ramfnmadman ramfnmadman is offline
Vehicle: 1997 Dodge 1500 4x4
Trim Level: SLT Laramie
ramfnmadman is on a distinguished road
Default Max tire size?
Okay I have a 97 1500 4x4 I just ordered a 5" suspension lift and 3" body lift. I have a 15x10 wheel with a 3 3/8 backspacing. Just curious as to what u guys think the largest tire I can run is. Rubbing on the fron fender will not be an issue I have a replacement front bumper and tons of clearance there.
Old 05-26-2011, 12:08 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 05-26-2011, 01:27 AM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
If you go on the website for Mickey Thompson tires they have a chart on there that has different types and years of trucks, amount of lift and the max tire size for that lift.
Old 05-26-2011, 03:06 AM
The problem with those guides is they are always way too conservative I mean most say it takes 5" to clear 35s well I'm sitting on 35s bone stock with only wheel replacement and bumper replacement for extra clearance. They don't rub at all not even at full turn. I am leaning towards a 39.5 x 13.5 because I've seen a few people on here with that combo was just hoping a few of them would confirm or give input.
Old 05-26-2011, 10:20 AM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
You need to consider more than just clearance... large skins (above 35's) put a lot of extra stress on stock driveline components, including the tranny and transfer case. Expect to see increased wear and perhaps breakage on things like bearings, axles, and joints, especially if you do any serious off-roading.
Old 05-26-2011, 01:53 PM
I'm not worried about axles my truck is sitting on a dana 70 rear and a dana 60 front both built with chromoly axles lockers and gears. When the tranny and transfer case go I will upgrade. I spent all my mony in the beggining on axles because I knew I wanted to go big. Got lucky and found a 98 2500llocally that had been wrecked and got both axles cheap and had them built. This isn't my first rodeo in the 4x4 world just have never had a ram so I'm not sure on clearance.
Old 05-26-2011, 03:14 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
Yea, I'd say you have the driveline covered! Be sure to post some pictures!!
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Tire size feature not accurate FDBDW Diablo Predator Questions & Info! 6 01-26-2011 08:05 AM
Tire Size 01RAMguy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 04-21-2010 11:37 PM
1.5 in lift max tire size RacerXisRad Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 11-22-2009 07:24 PM
