Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 05-26-2011, 12:54 PM
heckdogg heckdogg is offline
Vehicle: 2009 Dodge Ram
heckdogg is on a distinguished road
Default Voice Command/Bluetooth Question
so I just got my build sheet from Chrysler for my '09 SLT. It says my truck should have option "RSPP Uconnect Voice Command w/Bluetooth" I do have the REN radio, but when I push the Uconnect buttons nothing happens, I just assumed I had the REN radio without the bluetooth.
I did buy the truck used, so is there something I'm missing, or should I take it back to the dealer?
Thanks.
Old 05-27-2011, 12:58 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I'd check with the dealer, they might help. Any way, it's time to .................... this back to the top!
Old 05-27-2011, 01:01 AM
Heck, it says you have it. Better go find out why it ain't workin' as long as you have followed the steps outlined in the owner's manual on activation and set up for the UConnect system. If not, try that first!
Old 05-27-2011, 01:05 AM
Rep:2705
the dealer is suppose to activate the Uconnect ( bluetooth )
Old 05-27-2011, 01:44 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Dealer time! The Uconnect system, if working, allows you to setup the bluetooth via voice commands.
brad
Interested in one of my mods?
Old 05-27-2011, 03:01 PM
So, just for my understanding...The uconnect hardware may be present, but the dealer has to activate it?
thanks.
Old 06-03-2011, 04:28 PM
just to "add to the story," took my truck to the dealer last night after the MIL light came on. Pulled 3 codes, 2 for vacuum leaks and 1 for "radio has lost bluetooth connection with phone" I am dropping it off Tuesday morning for them to take a look at.
Old 06-04-2011, 08:57 PM
Rep:2705
I have my radio on & then press the symbol with the profile of a guys face speaking, as long as my cell phone is PAIRED to the radio, a list comes up on the screen & then the gals voice asks what i like to do & than reads the options, then i say CALL & it confirms my request & asks me who to call, i can say a name that i programmed in, or give a phone number, it repeats the number asks if it is correct, i say yes & the number is dialed
NOTE:
my hands free sound had to be reset after i got the Ram, it was too low to really be heard, i forget if i did that using the radios main menu or the radio settings.
the Navigation voice is the same volume as the phone volume
with the navigation using hands free voice, you push the hard key Nav button & the screen comes up, then press the profile of the guy speaking, it will pop up a list then read it to you, you make your choices as they are asked, it will allow you to change destinations, etc. while moving
The VOICE will not work well if your windows are open or your ac/heater fan is above the LOW setting
Old 06-08-2011, 12:49 PM
got my truck back last night, they had to reset the bluetooth module, everything works now!
Pre purchase question: U-Connect iPod Question NumberCruncher Electrical 2 02-01-2011 11:55 PM
Cam Question dodgeguy123 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 01-19-2011 03:05 AM
coolant line question 97ram1500 Heating & Cooling 1 09-28-2010 05:18 PM
factory exhaust question tough question 460hpmach1 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 13 05-26-2010 10:47 PM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
