behind the stock bumper winch mounting - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 05-26-2011, 01:23 PM
fightnite61 fightnite61 is offline
Vehicle: 2010 ram 1500 4x4 quad cab 4.7
Color: Lt Gray
fightnite61 is on a distinguished road
Default behind the stock bumper winch mounting
Has anyone been through the winch mounting process on 2010 ram 1500?
I intend to have a clean look to the front of the truck and therefore wish to mount a 10,000lb winch behind the stock bumper. Any thoughts on the idea and if you have done this already things I should watch out for. Thanks
Old 05-26-2011, 01:29 PM
I seem to remember running across Warn's behind the bumper system. It was on a 2008 (little bit different front fascia) but that might be a good place to start looking!
Old 05-26-2011, 01:37 PM
Rep:2962
i know that they have that setup on the 2500s on Gen 4s
maybe on the 1500 Outdoorsman too
Old 05-26-2011, 10:28 PM
jc4041's Avatar
jc4041 jc4041 is offline
Vehicle: 2009 QC 4wd
Rep:146
jc4041 will become famous soon enoughjc4041 will become famous soon enough
what about the front mount hitch type?
Ram DSP, CAI, Cherry Bomb Extreme, AirLift 1000
'07 Dodge Charger SRT8 SuperBee #579-CAI, DSP, dual Cherry Bomb Extremes
'07 GCSRT CAI, custom tune, custom exhaust
Old 05-27-2011, 09:10 AM
Color: Lt Gray
The outdoorsman is not offered with a front winch like the 2500 power wagons, The power wagon front mounts may be where I start at though. Waren hasnt offered any sugestions as yet with two e-mails to their customer service over the last month. It looks like I am gona be the first to attempt this. I will keep the post updated and add pics of where this project ends up. Thanks for the comments.
Old 05-28-2011, 01:12 PM
daleoregon daleoregon is offline
Vehicle: 2011 Dodge RAM 1500
Trim Level: SLT Big Horn Edition
daleoregon is on a distinguished road
I had a 2008 RAM 2500 with an ARB bumper and winch mount. Now have a 2011 RAM 1500 and thinking about another winch. Mine has the chrome bumper with a bit of space along the front that is filled with a black plastic insert. I have crawled under mine to look at options that did not require replacing the bumper.
It looks like there is plenty of room behind the bumper for a winch. I have done some searching and so far have not found a mounting kit for one. I also considered a front receiver which allowing me to go with a hitch mounted winch that I could then use on the front or back of the truck as might suit me best in any given situation. I haven't measured yet but it looks like some bumper cutting would be needed for a front mounted receiver.
Searching on line the only front receiver mount I found was below the front bumper. That seems a bit low and I would prefer it higher. So far it looks like a custom fabrication job based on my searching. If anyone comes across a high front receiver or behind the bumper mount for a 1500 I would like to know.
2011 RAM 1500 Quad Cab 5.7 Hemi 4X4 with Canopy & Bed Slide
Old 05-28-2011, 04:36 PM
Rep:2962
Curt Mfg 2011 Dodge Ram Front Mount Receiver Hitch 31015 Front Mount Receiver Hitch - Concealed
CURT Front Mount Receiver Hitch 31374
http://www.etrailer.com/Front-Hitch/...eid=2011301029
http://www.etrailer.com/vehicle-find...del=Ram+Pickup
you can always get a cradle type winch that fits into the receiver & use it on both the front & rear receivers, just need to run the power source to do it
http://www.cabelas.com/ensemble/Auto...type%3Dproduct
http://www.etrailer.com/dept-pg-Acce...ric_Winch.aspx
Old 05-28-2011, 06:09 PM
I found that Curt model in my searching. Has a great pull rating (9K) but I'm not happy about how low it places the receiver. It appears to be below the frame, at the top edge of the plastic valance that runs under the bumper. I don't like the idea of something really solid any lower than necessary - Imagine hitting a high curb with that. I would like to find a receiver mount that is closer to the height of the back receiver - something coming out in that gap in the front bumper. I haven't measured but think it would take a little trimming of the front bumper to make it fit. I'm not sure how hard that task would be.
Old 05-28-2011, 09:23 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I've seen hitches that bolt to your tow hook location in the opening. Cant seem to find the pictures now though
Old 06-03-2011, 12:02 PM
Color: Lt Gray
Well I have the warn universal mount and a welder so pics of the custom install will be posted soon I hope
bumpers, winch
09-11 Rear Bumper Removal and Replacement marko7717 Dodge Ram Knowledge Base 16 08-01-2014 06:15 PM
Stock dual bumper ? 916Timmy Exhaust 14 01-05-2011 08:33 PM
Bad Front Bumper Fascia Replacement/Repair BigEmpty Body & Interior 21 12-01-2010 07:40 PM
looking for a stock rear bumper for 03 ram LinebackerM52 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 08-11-2010 10:28 PM
09 stock rear bumper.... 08greybeast LD RAM - General Discussion 1 11-02-2009 05:19 PM
