Old 05-26-2011, 07:24 PM
zanegriffin zanegriffin is offline
Trim Level: Lone Star
Color: Blue
zanegriffin is on a distinguished road
Default Best Performance Exhaust
I have a completely stock 2010 Ram with A 4.7 .... strictly from a Performance/HP/MPG stand point what is the best exhaust/muffler i can get and what size pipes are best for creating non resricting flow and sucking bad gasses out and pulling more air in to the motor ... im planning on leaving the stock cat... sound is second to performance
Old 05-26-2011, 07:27 PM
Probably the Flowmaster Series 40 or 50 will flow the best of all the mufflers with the possible exception of the Cherry Bomb.
Stick with the stock sized pipes because if you go too large, you'll end up losing low end torque and that's what moves the truck.
Old 05-26-2011, 07:30 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
I just put a Flowmaster 40 on and saw the MPG increase. The sound is also awesome.
sales@revelperformance.com
Old 05-26-2011, 07:31 PM
Color: Blue
As far as cherry bomb mabe a glasspack ?
Old 05-26-2011, 07:33 PM
That's basically what the Cherry Bomb is...
Old 05-26-2011, 07:37 PM
Color: Blue
Also which is better two mufflers or one
Old 05-26-2011, 07:41 PM
For your 4.7L I'd suggest one muffler. True duals won't help you and may even hurt the performance.
You can go with a single in and dual out muffler and have two tail pipes if ya want. That won't hurt the performance.
Old 05-27-2011, 11:48 PM
Color: Blue
thanks alot buddy
Old 05-28-2011, 12:47 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
once again maddog comes through with excellent info to help a guy out
Old 05-29-2011, 10:42 AM
Flaminchiten Flaminchiten is offline
Vehicle: 2010 Ram 1500
Rep:42
Flaminchiten is on a distinguished road
Muffler Flow Testing
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 “ Straight Pipe 365 CFM
2 “ Straight Pipe 521 CFM
2 ” Typical Bent tailpipe 268 CFM
2 ” Typical Bent Tailpipe 417 CFM
2 ” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ” Cherry Bomb 239 CFM
2 ” Cherry Bomb 294 CFM
2 ” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ” Inlet/Outlet Gibson Superflow 267 CFM
2 ” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ” Inlet/Outlet Thrush CVX 260 CFM
2 ” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ” Inlet/Outlet Hooker Max Flow 521 CFM
2 ” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ” Inlet/Outlet 138-152 CFM
Standard OEM 2 ” Inlet/Outlet 161-197 CFM
This test was performed by 5.0 Mustang & Super Fords Magazine, December 2002 issue (page 55) on a '90 Mustang LX coupe with 370hp and 11 second potential. 66 pulls were made for this comparison:
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
Best Performance Exhaust DeepWaterHemi Exhaust 6 05-30-2010 11:00 AM
Performance Exhaust GPSHSLAX Exhaust 0 11-19-2009 12:57 PM
09 Ram Performance Tune and Exhaust Released 1970 Charger Exhaust 9 10-18-2009 11:53 PM
Hurst Performance debuts THE LEGENDARY black & gold COLORs on the Hurst Challenger!! GT Automotive Industry News and Dodge Press Releases 0 03-30-2009 08:56 PM
