MOPAR DECALS
Old 05-26-2011, 07:54 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Default Looking for info on rear coils
I'm trying to get as much info on stock rear coils for the 4th gen rams. I'm trying to gather the info, then am going to give it to another member, and he is going to forward it to a contact he has through a company to help them with their kits. We are looking for rear spring overall lengths (out of the truck), also looking for part numbers, please post your year, driver side vs. passenger side (they may be different), and other pertinent info like cab and bed size, and drivetrain. Thank you in advance! As of now we only have a '09 crew cab, and a '11 R/T, and I am '10 quad cab so will try to get that info myself, if anyone else can post up that'd be great!
Sean
Old 05-29-2011, 01:01 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 05-29-2011, 01:28 AM
Rep:2875
'09 Ram 1500 quad cab
you can ask the parts dept at the dealership to check out the measurements
ZASP spring - Left Rear
ZPSP spring - Right Rear
the fronts are
ZAMP spring - Left Front
ZNMP spring - Right Front
Old 05-30-2011, 08:13 AM
snrusnak's Avatar
Rep:1388
Thanks! strange, the 09 crew cab spring part numbers are all numbers, your 09 quad cab part numbers are all letters....
Sean
Old 05-30-2011, 08:21 AM
snrusnak's Avatar
Rep:1388
Also, I assume you're a 2wd?
Sean
Old 06-01-2011, 09:40 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
anyone else still have their factory coils laying around?
Old 06-01-2011, 11:21 AM
snrusnak's Avatar
Rep:1388
I'll be pulling mine out maybe next weekend or the following, will add my measurements to the few others we have. Any others would be great! Even just part numbers would help.
Sean
Old 06-07-2011, 11:39 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
Just cut mine a few weeks ago, so no part numbers left. However, they did have the same part number on the left and right hand sides. This was on my 2010 RCSB 4x4.
Bilstein Leveling Struts @2.8", 35x12.50 Toyo Open Country A/T II Extremes, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 06-08-2011, 12:35 AM
Rep:2875
those letters that i posted are they way Dodge identifies them on the build sheet
you have to talk to the parts dept to cross reference them to actual dimensions
Old 06-10-2011, 04:23 PM
snrusnak's Avatar
Rep:1388
Hmmm my build sheet doesn't have that on it....
I recieved a set of rear coils from chuckie on this forum, off an R/T. The weekend after fathers day I plan to swap them with mine, and compare lengths, etc...and will compile what little info we have on all the springs. I hope they have a little bit of a drop to them, I'm sure they will as they are from a regular cab and mine is a quad cab(not convinced the R/T has unique springs)
Sean
does dodge ram have issues with rear ends on there trucks ? nitro1965 5.7L V8 Specific Topics 12 10-24-2016 06:46 AM
Rear End SHOT! BOSS 32V 5.7L V8 Specific Topics 19 02-15-2016 11:31 PM
For anyone interested in cutting the rear coils chithead Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 24 05-20-2011 07:23 PM
Resolved - rear end loose metal sound, reverse rubbing, burning smell jjsmithii 5.7L V8 Specific Topics 2 02-25-2011 02:13 AM
Found..09 rear lowering coils CHVYKLR Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 12 12-02-2010 09:01 AM
