New to diesel - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 05-27-2011, 01:00 PM
JoeH88 JoeH88 is offline
Vehicle: 1999 Dodge Ram 2500
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
JoeH88 is on a distinguished road
Default New to diesel
I just bought a 1999 Ram 2500 with the cummins. Im wanting to know some basic boltons for a little more power without hurting reliability.
Thanks!
Old 05-27-2011, 05:10 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Cold air intake, Straight pipe exhaust and tuner are the basics
Old 05-27-2011, 10:10 PM
Rep:3347
Look at a 4-5" turbo back exhaust, a high-ram intake elbow (the stock one will make you cry when you see the difference), a cold air intake (which won't do much admitedly but every bit helps), and lastly a programmer coupled with a quick change module. For Tuners on the 5.9L, I would recommend the Banks iQ with thier 6-shooter, a bully dog, or an Edge Juice with Attitude. Running any of those tuners with their optional on-the-fly selector will truly blow you away... and PS... don't run the crazy setting very often unless you plan to really beef up the engine; but the lower settings easily boost the engine by 100HP and 2-300 ft-lbs of torque.
Old 05-28-2011, 09:28 PM
Thanks for the replies. I have another ? Ive been told running a programmer can hurt the injection pump, is that true?
Thanks
Old 05-28-2011, 10:47 PM
Rep:3347
You'll damage the pump if you run too high a pressure, but most programers aren't capable of turning up the pressure to a point where it'd damage the stock injectors due to the mechanical aspect of the pump itself. The only time I've heard of issues with pumps has been with the common rail since the fuel rails can handle an insane amount of pressure.
Old 06-01-2011, 02:46 PM
Thanks guys!
What prodrammer would you reccomend?
Thanks again
Old 06-05-2011, 09:21 AM
I was thinking about the hypertech hyperpac. Does anyone have any expierence with it?
Thanks!
Old 06-05-2011, 10:39 AM
Slipknot Slipknot is offline
Vehicle: 2008 Dodge Challenger
Trim Level: SRT-8
Color: Hemi Orange
Slipknot is on a distinguished road
I ordered a Edge EZ,because i want to build my tranny before getting the higher hp programmers..Should be here Tuesday/Wednesday..I think its a 60-70hp max programmer.. Later on ill be going with the Edge Juice CS/Smarty combo
Old 06-06-2011, 11:52 AM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
Anything that increases your hp by about 90-100 will put a real strain on your stock turbo and trans(if it's an automatic). If your going to rebuild your trans you might check out Goerend Trans. They are the best there is and their parts are bullet proof(although not cheap). Also don't forget a good set of gauges--Boost, EGT, trans temp and fuel pressure. Your Edge is a good choice.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
Old 06-06-2011, 01:58 PM
Hey i checked the fuel pressure gauge on the fuel filter. At idle it said 5 psi. Is that ok or should i do something about that first?
Thanks guys
2010 6.7 Cummins Diesel Slow Sluggish Acceleration ehillman Cummins Diesel Specific Topics 23 09-05-2015 11:49 AM
NHRDA Northwest Diesel Nationals, Spokane Washington NHRDA Drag Racing Discussion 1 05-12-2011 08:00 PM
3rd Annual Jefferson State Diesel Nationals, Redding CA May 14th NHRDA Drag Racing Discussion 2 05-12-2011 12:03 AM
Diesel Tunes Performance Chip knsram LD RAM - General Discussion 5 02-04-2011 12:08 PM
1992 Dodge Ram w/ Cummins diesel Tranny options? Russ Bellinis Cummins Diesel Specific Topics 2 06-11-2009 02:55 PM
