Old 05-29-2011, 07:41 PM
spacejunkie spacejunkie is offline
Vehicle: 1995 Dodge Ram 1500
Rep:45
spacejunkie is on a distinguished road
Default Today's project - Replacement Dash
I found a good dash at a pick-n-pull, except it was red. 25.00 for that and another 25.00 for 2 cans of primer and 3 cans of grey. Spent a couple days applying that and 2 coats of clear.
My 14 year old and I spent another hour installing it today. I did leave out the dozen screws located above the glove box. We used 2 sided 3-m foam tape there in the hopes it would give a little flex and not crack. And heres the finished project!008.jpg009.jpg
Old 05-29-2011, 07:58 PM
Rep:2657
nice job
most of the reason the original dash cracked, from my understanding, is that the screws were tightened just a bit too much & didn't allow for any flex. That & the sun did the rest
Old 05-30-2011, 12:40 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Nice Job! The old dash altered the definition of 'cracked' a bit.
brad
Interested in one of my mods?
Old 05-30-2011, 01:19 PM
That looks great! Nice work!!!
Old 06-18-2011, 02:53 PM
BroncoLee BroncoLee is offline
Vehicle: 1996 Dodge Ram 1500
BroncoLee is on a distinguished road
Great work. I need to do both of these projects on my '96 as well. How hard were they to get out? I doubt I can find a used dash that's together around here with this Texas heat. (I'm close to Houston.) Not sure of anyone that sells a new one other than Dodge...
Where are you getting the material to recover the top?
Old 06-21-2011, 02:38 AM
Rep:45
Default Replacement dash
I found the replacement dash at a local pick-n-pull salvage yard. Took about an hour of cursing and effort to get it out without breaking it. If my brother hadn't been with me, I would have just ordered one of the ABS dash covers for it for about 140.00, But with his help we were able to get it out and it only cost me 35.00 plus about 30.00 for the paint.
For the headliner, I used some velour fabric from a fabric store. The problem is that it is a very heavy material and didn't last very long, it started sagging within 48 hours. I have since scrapped the velour and had a professional redo it with a high grade auto fabric, going to install that this weekend. Next will be the door panel fabric.
Bill in SLC
Old 06-21-2011, 09:17 AM
I may try and go look at the yards to see if I can find a dash. Other option for me would be to buy a new factory dash new for around $255.
I need to do my headliner too but likely can wait for that. How much did it cost to have a pro do the headliner with you taking it out? (Or did you take it back out?)
Thanks,
Lee
Old 06-22-2011, 05:01 PM
97 5.9 MAG's Avatar
97 5.9 MAG 97 5.9 MAG is offline
Vehicle: 1997 Ram 1500 2wd ext cab 5.9
97 5.9 MAG is on a distinguished road
That looks sweet man. Mine is cracked terribly and now with the level kit everytime u hit a bump it just cracks more and rattles like you wouldnt believe! lol With the dash caps dosent that just get glued on to the origonal dash?? Has anyone had luck with that? I thought about a new dash because my cup holder brackets are broken and so is my fog and od button brackets... Any thoughts on a 98 conversion??
Old 06-25-2011, 04:55 PM
bamamopar's Avatar
bamamopar bamamopar is offline
Vehicle: 2001 dodge ram sport off road
Trim Level: sport 4x4
Color: blue
bamamopar is on a distinguished road
dang that looks pretty good i gotta do that to mine bad
Old 06-25-2011, 06:43 PM
flacrkr1ton's Avatar
flacrkr1ton flacrkr1ton is offline
Vehicle: 1998 ram 3500 drw
Trim Level: SPORT
Color: RED
flacrkr1ton is on a distinguished road
I gotta do mine also however i found a fiberglass reproduction on e bay same prices as the abs ones but glass don't figure it'll crack again,genos has the replacements for 3 somthin income tax time will be orderin a dash and replacing the ac evap and heater core.
Red neck engineerin beat to fit paint to match
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 10:22 PM
03 Ram Dash defroster grille replacement brock1sampson9 Body & Interior 4 01-15-2011 11:05 PM
Anyone successfull with getting a dash replacement angelicshadows Body & Interior 4 12-08-2010 11:58 PM
Newbie needs dash replacement for 97 Ram Headhunter843 Newbie Checkin! 12 10-16-2010 01:38 AM
Dash removal/ Heater core replacement Trishafer Heating & Cooling 6 02-25-2010 06:23 PM
