Old 05-29-2011, 08:46 PM
Ram98's Avatar
Ram98 Ram98 is offline
Vehicle: '98 Ram 1500 , 2004 Rumble Bee
Trim Level: Sport,Rumble Bee
Color: Blue, Yellow
Rep:28
Ram98 is on a distinguished road
Default replacing left front axel seal
Wondering if anyone has replaced the left front axle seal and how they removed it and reinstalled it. Already have the hub bearing assembly(what a bear that was!) and axle out.
98 Ram 1500 Sport 4x4 5.9L
2004 Ram 1500 4x4 Rumble Bee
Old 05-30-2011, 04:26 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 07-09-2011, 10:47 AM
FF54 FF54 is offline
Vehicle: 1998 Dodge Ram
Color: Ford Woodland Green with black added
Rep:26
FF54 is on a distinguished road
I realize this is an older thread, but don't do it. I did the passenger side last night. I found out dodge actually reccomends buying two seals. You are gauranteed to screw one up. The next thing they say to do is to pull the center section out. I just pulled the shift fork off an housing off when I did mine. Because the passenger side acutally does come out by going towards the driver side, so Im assuming the driver side would have to go out by being pulled/pushed towards the center section. Here's my recommendation. Pull the axle. Rebuild so you have a dang near brand new axle, or buy another axle you know is good.
100% serious in this entire post.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
Front of truck not level - Left to Right NCBowhunter Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 10-11-2010 10:33 AM
Changing front left turn signal harley30041 Body & Interior 2 01-02-2010 04:15 PM
Makes a weird noise turning left?! r3d47 Suspension 11 06-22-2009 08:08 PM
Friend's 02 Ram 4.7L Left Oil Filter Seal, Major Engine Damage lou4gehrig Dodge Ram General Discussion 7 03-06-2009 04:41 PM
