Old 05-29-2011, 09:48 PM
quadboy47 quadboy47 is offline
Gender: Not Specified
quadboy47 is on a distinguished road
Default Moto Metal Tire and Wheel Size?
I am looking at purchasing some Moto Metal 951's. I have a 2006 Ram 1500 QuadCab. I am up in the air on what size wheel to go with either a 18" or 20" w/ 35's. Its my understanding that am gonna need at least a leveling kit in the front to clear the tires. Does anyone have any suggestions on what size to go with along with tire size? A am hoping for something that would give some width along with some height. Also, if someone knew of a good website to purchase from that would help alot.
Thanks Alot
Old 05-30-2011, 12:52 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Ahhh good choice of wheel! I love those 951's. 18's will be somewhat cheaper and will look plenty big enough. I'd just stick with those. And if you're going to run 35x12.5's, I'd recommend at least -12mm offset so you that you can try and stay away from spacers. If you're going with just a leveling kit, I'd recommend just 33's. They look less stuffed in the wheel wells IMO. As for a website, I'd check out 4wheelparts.com They always have some kind of special running. Back before christmas, I actually got my wheels for %20 off and with free shipping!
Old 05-30-2011, 01:18 PM
I agree...18's will be cheaper and give you a good sized sidewall.
The offset of -12mm will allow you to go to a 12.50 tire with no rubbing.
A level kit won't give you the vertical clearance you need for 35's, however. It's either go with some 33's or a 4" lift for 35's.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 10:40 PM
Tire and wheel size? Wade.S Dodge Ram Wheels And Tires 12 12-17-2010 10:25 PM
Will this size tire fit the stock 20" wheel BenSamp Dodge Ram Wheels And Tires 1 10-24-2010 08:49 PM
Tire and wheel size help? BamaRam09 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 12-29-2009 09:20 AM
