Old 07-13-2011, 11:23 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2012 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
Looks good, better than stock.
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 07-14-2011, 09:37 AM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Originally Posted by EVS1 View Post
How does it install?
The AMI fuel doors use the same 2 mounting holes the stock fuel door mounts with. After you remove the stock door, you pull the two little rubber stops on the right side of the opening, and the AMI door has 2 studs that go through the stock screw holes. There's a couple of small nuts that go on the backside (an offset wrench makes this much easier) and you're set.
Old 07-16-2011, 03:32 PM
RussellTech's Avatar
RussellTech RussellTech is offline
Vehicle: 2008 Dodge Ram 1500 5.7l
Rep:16
RussellTech is on a distinguished road
sfa1500 I ordered the fuel door online from truckaddons.com, taxes in and shipping to Canada it came out to $130.
upstater good description on how the fuel door installs. The only thing I would add is that you will have to spend a little time shimming the door to fit flush. The kit comes with supplied spacers(steel washers) which you will use to space the door in or out. Because the bed of the trucks panel is slightly curved and the door is flat, it will take a few attempts to get it just right.
2.5" Hell Bent Steel leveling kit, K&N CAI, Superchips flashpaq (3865), PIAA 4000k bulbs
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Locking fuel door. Necessary? Rambo11 Dodge Ram General Discussion 25 06-22-2012 06:37 AM
Locking billet gas door ftw wester399 Dodge Ram General Discussion 9 03-12-2011 02:06 AM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
