Old 05-30-2011, 04:08 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Default Mod10 - Debadge
I finally got to the Debadging.
Picked up the fishing line and adhesive remover on Friday, so after work I started on the tailgate.
Here are the 'required' items - 3M General Purpose Adhesive Remover, and 17lb fishing line.
Although not required, warming them up with a heat gun (Low heat - I set mine to 250deg F) makes it easier.
Use gloves to hold the fishing line.
Work your way in a sawing motion behind the badges.
Just about done. This part of the process took about 10 seconds. Warmed with the heat gun on a sunny day = real easy!
So far, so good. Now to get rid of the tape that held them on.
This next section is how NOT to remove the tape and adhesive....that's right....I fully documented the WRONG approach.
Hopefully this helps out someone else that is planning to do this. Later in this thread, I have a much better way of dealing with the tape and adhesive.
brad
Interested in one of my mods?
Old 05-30-2011, 04:10 AM
brad12kx's Avatar
Rep:2581
Following the directions on the can, I sprayed on the adhesive remover, let it sit a moment, and re-sprayed a few times to keep it damp. I then used the dry rag as instructed, and
discovered that after 5 minutes of ZERO results, that an alternate approach was necessary.
So I pulled out my trusty squeegee that is normally used to apply vinyl decals....
and carefully scraped at the bulky part of the tape to remove as much as possible without touch the paint with the squeegee.
Then I re-sprayed with the adhesive remover, and started to wipe...
and spray and wipe.....
15minutes of spraying and wiping later......
5 more minutes....
15 more minutes....
Lets try a different kind of rag...terry cloth...
10 more minutes.....terry cloth was no more effective.
Oh goodie! It only took 1-1/2 hours to make swirl marks in the paint.
At least the 4x4 badge is gone, and you can't see the swirl marks from a block away at 60mph.
The next section is the sides of the truck. I wasn't about to go for a repeat performance of Friday, but I really wanted to complete the mod.
brad
Old 05-30-2011, 04:14 AM
brad12kx's Avatar
Rep:2581
So here it is Sunday, it's cold, threatening to rain.....completely opposite weather.....what could go wrong?
Here is the B4 picture.
A second B4 picture....we all like pix?? Don't' we ??
Using the same procedure to remove the badges, here is the infamous tape left on the truck.
After heating the tape and carefully scraping at it with a plastic bond scraper for about 10 minutes and only had the 'M' and the 'A' scraped....I had an idea
For those that are wondering "What the heck is Pro-Gaff". This the tape we use in the entertainment industry to tape down cables, and anything else that most people use duct tape
for. It has a tight weave cloth back and holds it's glue very well, and sticks much better than duct tape and doesn't leave a glue residue behind when you remove it.
I'm up to the 'R' when I try this concept....Heat the 'R', apply the Pro-gaff and using it to hold the adhesive tape together, I pulled it an 90deg to the paint, and slowing pushed at the
bonding edge of the adhesive while pulling on gaff tape.
In a few seconds, I had the 'R' off, and most of the adhesive tape came off. You can see the difference between it and 'A'.
Here's another shot showing the difference in the remaining adhesive.
Here is the gaff tape with the 'R' tape stuck to it.
Sprayed on the adhesive remover, and wiped off with a soft dry rag. The 'A' & 'M' caused a bit of grief, but the 'R' and the 'Hemi" can off super easy.
A left and right set of badges!
Next I did the passenger side. From starting with the heat gun to this stage - 15 minutes + 5 minutes to remove the adhesive = 20minutes!
After cleaning off the adhesive, I rubbed the area down with a clay bar. It almost erased the shadow of the badges.
brad
Old 05-30-2011, 04:15 AM
brad12kx's Avatar
Rep:2581
Here are some shots of the final result.
In the beginning, I was hesitant to debadge. Right now, I am so glad I did. Who would have thought that such a small thing could make such a big difference.....other than every Z
member that has already done this.
brad
Old 05-30-2011, 07:47 AM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:589
Great looking truck , love the results. Great write up as well!!
RICHARD
Old 05-30-2011, 08:09 AM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Looks great , did you try buffing out the swirl marks on the tail gate with a little wax
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 05-30-2011, 08:39 AM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Duck tape (pro gaff) worked amazing!
Have never seen that approach before.
I used the old heat up the tape and roll with the fingers. Worked fine just took a toll & a few blisters on the hands.
Nice looking truck though man, definitely looks better de-badged! The only badge I left on was my Hemi! It has a black accent in it to match the white truck so I said what the hell.
Old 05-30-2011, 09:47 AM
brad12kx's Avatar
Rep:2581
Thanks yamifz1. It's always nice to receive reps after spending hours of culling, cropping and resizing pix for a thread that you stay up until 3am to post. LOL
I guess I did forget to mention the waxing, polishing and buffing to erase the tell-tale efforts of debadge done wrong.
LOL....after doing the similar thing with the 'A' & 'M', and although I was using a plastic scraper, the fingers were very much involved. The 'duct tape' idea came along similar to a bathroom moment.
I struggled with whether or not to remove the Hemi badge, so decided to leave it on for awhile and possibly remove it at a later date. However....in the heat of the moment....opps! In the end I'm very pleased with the results.
brad
Old 05-30-2011, 11:03 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Wow Brad, I'm impressed and thanks for sending me the PM that directed me here so I can properly acknowledge your efforts.
Old 05-30-2011, 11:10 PM
brad12kx's Avatar
Rep:2581
Thanks Randall. Like I said, after seeing your debadge; it was enough to push me over the edge to do mine. Thanks for the inspiration. I am so happy with the result.
brad
Should I Debadge My Truck? DeputyNelson Dodge Ram Forum Polls! 54 12-04-2014 09:36 AM
Next Mod....Debadge RedDodge 2011 Dodge Ram Forum 9 05-31-2011 03:45 PM
HBS level kit, tint what tires and rims to buy? debadge? Bent21606 2011 Dodge Ram Forum 2 05-18-2011 06:15 PM
RAM Debadge pics TRIPOD Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 15 06-15-2010 09:58 PM
how to debadge CdnoilRAM Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 9 07-24-2009 07:59 PM
