Tire Valve Stem broken (known problem!?) - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-30-2011, 01:18 PM
Fresh12 Fresh12 is offline
Vehicle: 2008 Dodge Ram 1500
Fresh12 is on a distinguished road
Default Tire Valve Stem broken (known problem!?)
The tip of my valve stem where you would screw the cap on, broke off. I've read this a known issue. I was able to duct tape it for now and it has been fine for a week with a slow leak. Problem is that Tires Plus wants $100 to fix this which seems crazy. They said I would have to replace the entire stem with the sensor. Is this true? I found the stem online for $5. Why does the sensor need to be replaced too? I'm hoping you can help me out here. I'm thinking I can just order the piece online other than pay $100? Thanks!
Old 05-30-2011, 01:26 PM
The TPMS sensor and valve stem are one integrated assembly. You don't have two parts there.
I have not heard that there was a problem with the stems before.
Good luck and welcome to the forum!
Old 05-30-2011, 01:37 PM
Thanks for the quick reply. Hopefully you guys can help me get exactly what I'm looking for. I'm guessing this isn't it?
http://www.carparts.com/details/Dodg...ormanrb9740001
Old 05-30-2011, 01:41 PM
Ya know...I am not sure. I don't have TPMS on my truck and the TPMS units on my SRT look a lot different.
Remember, these operate on a wireless frequency and the TPMS unit needs to send on the right one to the receiver or it won't work.
I'd talk to a tire and wheel shop locally. They may be able to fix this for a lot less than $100 and make sure you get the right unit.
Old 05-30-2011, 05:09 PM
RAMitDOWN's Avatar
RAMitDOWN RAMitDOWN is offline
Vehicle: 09 Dodge Ram
Trim Level: ST 4X4
Rep:24
RAMitDOWN is on a distinguished road
It is/was a known problem when a metal cap is used because they corrode then you are unable to remove the cap without ruining the stem.
If you take a look at the dealer you will see "all" Rams have plastic valve stem caps.
http://www.ramforumz.com/showthread.php?t=56128&page=3
Old 05-30-2011, 05:40 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about posting a few photos of your truck? I've just replaced a few on one of my vehicles and the TPMS did unscrew to allow replacement if the valve stem. Go for the part you have on eBay. Any tire dealer should be able to do the replacement.
Hey, on another note since you're new to the site how about using the link in my SIG to jump over to the Newbie Checkin and introducing yourself and post a few photos for us?
Old 07-19-2013, 09:03 PM
drumstick54 drumstick54 is offline
Vehicle: 2009 Dodge Ram
Color: Gray
drumstick54 is on a distinguished road
Exclamation Valve stem defect potentially fatal.
My 2009 Ram has those el cheapo valve stem shrouds that shatter when corrosion gets between them and the stem. I found out the hard way that my life and the lives of everyone who drives with this system are in jeopardy. When checking the air in my steers the shroud broke and I didn't know what it was. I drove it to a repair shop and when turning into the parking lot, the stem broke altogether and my tire went flat immediately. Fortunately for me and others on the road, it happened at a low speed but if it had happened at 55 or above, it could have caused a very bad accident. The repair man told me he had seen many of these and had replaced the entire assembly which included the sensor. The unit costs over $60.00 plus labor. When I confronted my dealership with this, I was told that there had been no safety recall and that I had to pay for the replacements myself. So, I bought a vehicle that lists for over $38,000 and the whole thing depends on 39 cents worth of plastic? To say I'm disenchanted with Dodge would be an understatement. My advice is for everyone to check these stems and if possible, replace them with the rubber stem and sensor assemblies. The life you save may be your own.
Old 07-20-2013, 04:45 PM
Color: Gray
Exclamation Plastic or metal valve caps.
The valve caps on my 2009 Ram were all plastic and the stem still corroded to the point of breaking apart. Apparently, it doesn't matter which one you have. My advice is to replace all of them, even though it will be expensive. It's better than dying on the road at 55 mph from a blowout on your steering axle.
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Question about my spare tire YoMoma Dodge Ram Wheels And Tires 7 04-07-2010 01:43 PM
Tire Cupping with slight pull to right dodgeramdriver Dodge Ram Wheels And Tires 11 02-26-2010 07:07 PM
New Exhaust - spare tire issue (noob says hi) 04HemiGreg 5.7L V8 Specific Topics 9 02-16-2010 11:04 PM
New Exhaust - need help with spare tire (noob says hello) 04HemiGreg LD RAM - General Discussion 13 01-22-2010 04:40 PM
