Old 07-17-2011, 09:52 PM
DavidH DavidH is offline
Vehicle: 2009 Ram 1500 Quad Cab
Color: Metallic Beige
DavidH is on a distinguished road
Originally Posted by rick980 View Post
Okay correct me if I am wrong you now have a factory trailer braker working on on 09 RAM or is it a 10?
I have a 2009 Ram
Old 07-17-2011, 11:57 PM
rick980's Avatar
rick980 rick980 is offline
Vehicle: 2015 RAM Quad Cab Sport
rick980 is on a distinguished road
Are you using the wiring from the blue plug under the dash for part of it? An the rest is in the main harness coming in. I can't make heads nor tails of that 22 page forum. Did you go to the dealer to have it starscanned so it shows up in the EVIC etc? or you just have it working. I would not care if it worked in EVIC as long as if performs correctly.Can you message me and I will send you my email and maybe you can help me make heads or tails of this, I have been afraid to buy one but might, I am told by a trailer company that this type is going to be obsolete soon, any ideas about that?
Old 07-18-2011, 10:05 PM
The main pieces of the 22 page thread are Netman66 detailed description of how to mount the controller in the dash and Ken99's attached PDF file. Those were the 2 pieces I used which helped the most.
I do use the wiring from the blue connector for the "A" connection. I went to an RV and camper place and they had a pigtail that plugged right into the 2009 factory connector. All I had to do was put crimp on connectors on the leads and plug them into the controller. I have NOT been to the dealer to try flashing it yet. I am hoping someone on here might know the build code for the brake controller for the 2009 Ram. My understanding is it was never an option for the 2009 and therefore wouldn't have a build code. I have no idea why it would be obsolete soon. I'm also surprised the OEM brake controller doesn't work with just the wires from the blue connector since every aftermarket controller I looked at only uses 4 wires. If I had not been able to get this one working, I was going to use the bezel and attach an aftermarket one by drilling a hole in the sides of the bezel and running the screws thru the bezel and into the screw holes on the side of the aftermarket controller. I'll keep you posted once I go to the dealer but it may be a couple of weeks before I get that chance.
Apparently I need more posts before the site will let me bmail you.
Old 07-19-2011, 07:38 PM
BgHrn BgHrn is offline
Vehicle: 2006 Dodge Ram
BgHrn is on a distinguished road
So, you have to have a pigtail from the dealer, that plugs into the blue plug, under the dash? B/c Im in the same boat. Im in the middle of installing a brake controller and I dont see any other plugs, down there.
Sorry if I stole the topic.
06' Ram, molding!, In-channel visors, 3" Mag' SI/SO 18" long, Mag' y-pipe, 2" HBS Leveling kit/1" rear block ,DSP 91 tune, KN CAI kit, BFG 285/65r20 rubber.
Old 07-21-2011, 09:19 PM
the plug I have came from a RV and camper dealership. it is a pigtail for an aftermarket controller made for the 2009 dodge. it plugs into the blue plug on the dodge. i'll get the manufacturer & model # this weekend.
Old 07-21-2011, 10:00 PM
Ok, that might help. A picture also, if ya can. thanks!
Old 07-25-2011, 07:16 PM
rick980's Avatar
I have one of the blue plugs left over from one of my other pickups. So that part is no sweat.
Old 08-26-2011, 04:12 PM
rick980's Avatar
Dealer must be able to get it fits most of 2009 and below trucks with trailer wiring for several years. Mine was from a 2003 Durango or a 2000 Dakota I forget which one I kept.
Old 08-28-2011, 12:28 AM
ken99 ken99 is offline
Vehicle: 2010 Ram 1500 Crew 4x4
Color: Austin Tan Pearl
Rep:31
ken99 is on a distinguished road
Originally Posted by DavidH View Post
In that write up, it said to stay away from the twisted pair of wires (one white w/ blue and one white w/ green) because they went to the OBDC.
Originally Posted by Netman66 View Post
Before you cut and splice anything, simply plug that wire into the ODB2 connector where that wire lives and see if it works. If so, make the connection permanent.
If Bodybuilder says it's the same circuit, I can't imagine it wouldn't work.
I cautioned folks to not use the OBDC connector wires for fear that the diagnostics connector would be left disabled. It may be ok to tap into those wires, but I would connect a scanner to make sure the diagnostics are still working after installing the ITBM.
Old 09-11-2011, 08:34 PM
blurred vision blurred vision is offline
Vehicle: 2010 ram
blurred vision is on a distinguished road
How did this work out for you as I want the factory brake controller also for the clean look on my 09.
Installing Factory Brake Controller brc3858 2010 Dodge Ram Forum 17 05-07-2013 08:02 PM
2011 RAM 1500 integrated brake controller dodgebruce 2011 Dodge Ram Forum 4 06-02-2011 10:07 AM
Integrated Trailer Brake Controller Kit Update pmifsud 2010 Dodge Ram Forum 5 04-23-2011 01:09 PM
2010 Dodge Ram Integrated Brake Controller - Part # kurbanic LD RAM - General Discussion 1 04-11-2011 05:09 PM
Integrated Brake Controller Problems. galoot Newbie Checkin! 12 11-20-2010 11:35 PM
