Old 06-03-2011, 12:04 AM
thebrassnuckles thebrassnuckles is offline
Vehicle: 2011 Ram 1500
thebrassnuckles is on a distinguished road
you could also get some rock sliders and use them as a jack point.
Old 06-03-2011, 10:04 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
You would need some really stout rock sliders to support the weight of the truck, especially with the distance between the frame and the rockers.
Wade, have you ever used a Hi-Lift to winch with? It sucks! I mean it works, but it is awful painstaking work to move 2-3 feet at a time, then re-secure the vehicle to start all over. I have done it twice, and hope I never have to again. Much easier to just make sure you have a buddy with you to pull you out.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 06-16-2011, 10:36 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
I think my slider steps should be strong enough, I will definitely be doing some tests with the high-lift... when I finally finish them
I have used my high-lift more times for other fab work than actual lifting. You can use it as a big clamp/vise or to separate / pry things apart
Old 06-20-2011, 01:28 PM
Wildcat's Avatar
Rep:166
I wondered if you gave up on those since I hadn't seen any updates.
Old 06-20-2011, 02:19 PM
fundaddy75's Avatar
fundaddy75 fundaddy75 is offline
Vehicle: 2004, SLT, 3500 HD Tow Pack.
Trim Level: Slt Auto Cloth.
Rep:13
fundaddy75 is on a distinguished road
As you can see the truck moves very very little and you will need something to keep what little progress you have made. I have used many types of recovery systems and wildcat is dead on. Another truck of equal size is always the best.
As a Jack the Hi-Lift is great.
Just happy to be playing.
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 06:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
Where to Mount My Hi-Lift Jack? Quiet Lunatic Dodge Ram General Discussion 13 02-09-2011 07:03 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
