idle - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 05-30-2011, 10:30 PM
keegles's Avatar
keegles keegles is offline
Vehicle: 1998 dodge 1500
Color: driftwood
Rep:19
keegles is on a distinguished road
Default idle
how do i adjust the idle on my uncles 96 cummins? its not stock, its got a banks kit and turbo, exhaust upgrades and a bunch of other things. but he recently had the motor rebuilt and now the idle is really low. the mechanic doesnt want to tell him how to adjust the idle. anyone know how?
Old 05-31-2011, 01:48 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have an answer so, it's time to .................... this back to the top!
Old 06-06-2011, 08:57 PM
svetlecic's Avatar
svetlecic svetlecic is offline
Vehicle: 2011 laramie 1500 crew 4x4
Color: white monotone
Rep:13
svetlecic is on a distinguished road
Well i can tell you but its still going to be pretty hard to do.
Start buy finding your throttle linkage that is mounted to your injection pump. Under the linkage where it rests on the pump there is a set screw with a bolt running through it. You have to break the nut loose and then turn the bolt to move the throttle stop rest up. Then when you have it set at the correct idle tighten the nut. Also you will need to have a tachometer hooked up or some one in the truck with it runnning, in gear, with the a/c on. Your rpms should be between 850 to 900. The bolt is a 11mm if I remeber correctly. Having small hands and being double jointed doesnt hurt either!
285/65/20 BFG , Weather tech floor mats and vent visors , Amp Research Power boards , Console Vault , Mopar side door moldings painted bright white , Avs aero skin bug shield , Daystar leveling kit , Many more to come!:smileup:
Low idle, rough idle problem and more starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-17-2012 04:03 AM
1994 dodge ram check engine light- wont idle sometimes hillvalley 5.2L V8 Specific Topics 6 10-25-2011 10:35 PM
Best Performance Exhaust zanegriffin 2010 Dodge Ram Forum 9 05-29-2011 09:42 AM
Stalling in cold weather. Air Idle Valve? Todd F 5.9L V8 Specific Topics 3 12-06-2010 10:12 PM
Uneven idle yellow ram 5.9L V8 Specific Topics 2 05-29-2010 05:46 PM
