Old 05-31-2011, 01:21 AM
WesGee's Avatar
WesGee WesGee is offline
Vehicle: 2009 Dodge Ram
WesGee is on a distinguished road
Default Tire Question
Would a 33 inch 12.50 tire fit my stock 20s on my 09? And yes the tires are for 20s. Thanks for any advice
2009 Dodge Ram 4x4-Volant CAI-Flowmaster Exhaust-Leveling Kit-HID Headlights and Foglights-Step Bars-(4) KC Long Range Lights
Old 05-31-2011, 03:48 AM
jjride's Avatar
jjride jjride is offline
Vehicle: '10 Ram Sport
Trim Level: Sport Q/C
Color: PXR!!!
Rep:28
jjride is on a distinguished road
They will not fit with the factory wheel setup.
The tires will make contact with the upper control arm.
You can do this setup with wheel spacers if you choose to keep the factory 20's.
You need another .75" roughly to clear those arms.
And then, you may run into rubbing on the rear of the fender liner.. mudflaps depending on how thick they are can be an issue as well.
I'm sure someone here can verify this, but i do know for a fact that anything wider than 11.25 - 11.5" or so.. depending on the side lug of the tire, will rub that control arm on the factory 20's. Go ahead and take your hand and run it along the inside of the tire, at the top.. and that will tell you how much room you have... or don't have in this case. Your Factory tires on the 20's are 11" wide just so you know.
Easy solution.. alot of guys are running a 285 width in a mud tire and clearing with ease.
Hope that helps. Anyone can correct me if I'm wrong.
Old 05-31-2011, 01:14 PM
WesGee's Avatar
Thanks for the advice, it definitely helped!
Old 05-31-2011, 07:31 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:275
Not completley true. I am running 33/12.50R20 Toyo M/T on my factory 20's with no spacers. Admittedly they are close, but after carefull cycling of the suspension during full and partial steer and full compression and droop I can asure you they do not rub the upper control arm.
As for the fender you are right, you really need at least a leveling kit. or you will rub the rear bottom of the fender. With a 2.5" leveling kit and stock wheels I have no clearance issues with the 33/12.50R20 tires.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
Old 06-04-2011, 10:43 AM
jjride's Avatar
Color: PXR!!!
Rep:28
Good to know. I guess different tires vary as well. We put a Goodyear Kevlar in that size and the lugs grabbed that control arm. And if you can live with a bit of rub at full turning lock, then that will work fine. I hate with a passion, any kind of rubbing.
Long story short.. I stand partially corrected haha.
Old 06-04-2011, 11:35 AM
Rep:275
Seeing as Goodyear generally runs small to size I find that very interesting!
Old 06-04-2011, 01:39 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Stock tires on measure in to pretty much a 33" tire and I wanna say around 11" wide, your not gonna see much of a difference
Old 06-04-2011, 10:43 PM
Rep:275
Stock wrangler HP on mine new, factory recommended pressure mounted on the vehicle measured in at roughly 31.8" x 10.2.
Old 06-05-2011, 10:30 PM
Color: Mineral Gray
Rep:177
I guess I should say in theory the stock 275/60/20 is about 33" by 10.8". Every manufactures ruler is a little different
Can't say I've ever actually measured the height/width of the stock tire. I'll have to check it out next time I'm home
24" tire question Lakelandhuskers Dodge Ram Wheels And Tires 3 02-02-2011 12:45 AM
Newbie with tire question calbear Dodge Ram Wheels And Tires 8 01-15-2011 02:03 AM
Tire Pressure Sensor Question AKRAM Dodge Ram Wheels And Tires 3 11-21-2010 09:46 PM
Tire Question... rob Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 12-12-2009 10:53 PM
Low tire pressure indicator question imnxnyr Dodge Ram General Discussion 14 10-06-2009 11:49 PM
