Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 05-31-2011, 01:21 AM
Nate25 Nate25 is offline
Vehicle: 2008 Dodge Ram 1500
Nate25 is on a distinguished road
Default Question with 7 pin Wiring.
I bought my dodge back in November. Iit has the tow package on it (I requested a build sheet for the hitch class). I can find the blue plug in for the brake controller, but in the back I can only find a 4-pin wiring harness. Does this mean that I have to do a full 7-pin wiring job?
Its a 2008 Dodge Ram 1500 5.7L Hemi 4x4 Quad cab.
Thanks for your help,
Nate
Old 05-31-2011, 01:31 AM
Rep:2705
some companies make a 4 to 7 wiring harness adapter
you may have to play with this a bit
http://www.dodge.com/bodybuilder/200...d/drquadmo.pdf
Old 06-15-2011, 08:08 PM
Campndru's Avatar
Campndru Campndru is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: BigHorn Edition
Color: Inferno Red Crystal Pearlcoat
Campndru is on a distinguished road
I did this to my 07 QC a year or so ago. As I remember the color coding on the brake wire under the hood was different. I tracked it down with a tester. If you plan to charge a battery, you will also need to add the charge line from the battery to the 7-pin. It should be a min. of 10 guage wire and the wiring should include a fuse or relay (better if you want to avoid draining your vehicle battery).
Old 06-15-2011, 08:33 PM
Rep:2705
go to this site for 2008 Ram
click on the page numbers to see what each contains
http://www.dodge.com/bodybuilder/200...trailertow.pdf
Stereo wiring question... DodgeGuy85 Electrical 12 07-07-2013 07:57 PM
Headlight wiring question B and B LANDSCAPES Electrical 12 01-12-2012 04:40 PM
question about wiring lights to overhead console? strafen Custom Dodge Ram Interior and Exterior Lighting 10 05-23-2011 08:54 AM
R/T wiring harness question peej03 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 5 05-13-2010 10:56 PM
'99 318 1500 wiring loom question. Dieselkiss Electrical 5 02-22-2010 12:07 AM
