4.10 axle ratio, rpm vs speed???? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-31-2011, 12:36 AM
Whisky Creek Whisky Creek is offline
Vehicle: 2005 3500 SRW & 2011 3500 DRW
Color: Red/Silver
Whisky Creek is on a distinguished road
Question 4.10 axle ratio, rpm vs speed????
Hey guys. I ordered my 2011 Ram 3500 Dually a few months ago with a 4.10 axle ratio. I just picked it up last week and immediately pulled a trailer load of horses home to warm it up. (Amounted to about a 10000 lb total trailer weight) Then on the truck's second trip, yesterday, I hooked onto my tri-axle 28 ft stock trailer and loaded some cattle - 9 pairs, 1 heifer and a bull - into the three holes and took pulled them 350 km to another property for summer grazing. I weighed 14680 kg gross weight at the scales, and 6670 kg on the way home with the empty trailer. The cattle weighed 8010 kg (or a little over 17600 lbs) and I think the aluminum trailer weighs about 3500 lbs.
I managed to squeak under the legal GVWR licensed weight by 319 kgs, WITH all axle weights being legal as well! (Wow, even a blind dog finds a bone now and then!)
The truck pulled the load awesomely and I am REALLY impressed with the "hold back" capabilities of the factory exhaust brake on hills. Steep hills in the BC mountains here with that kind of weight and I didn't have to touch the brakes much at all, and not at all on many hills. As this is my "first" Ram equipped with an auto, I was a bit worried about it. With the exhaust brake on this truck, it easily out performs my 05 Ram with the manual tranny on the "down hill".
Anyways, sorry about the tangent, finally onto my question. How do you verify your axle ratio, easily? Short of putting it up on blocks...
I ordered it with 4.10 axle and I verified that information is on the order sheet, but I expected to have to tolerate much higher rpms at highway speed with the 4.10.
This truck has the 6 speed automatic transmission in it.
At 100 km per hour I am showing 1700 RPM when it is in 6th gear.
With the 6 speed manual transmission in my 2005 Ram, I am running about 2000 rpm to get the same 100 km/hr.
Does the fact that it is an automatic transmission have something to do with this difference?
What "actual" (ie: personally verified, not rumoured) rpm are you other guys getting with your 2011 Ram, 6 speed auto, 4.10 axle ratio'd trucks at 100 km/hr (60mph)?
Thanks...
Old 05-31-2011, 12:46 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
That sounds right.
The auto trans has 2 OD gears. Your old manual only had 1 OD gear.
I take it you 'Did Not' use tow/haul....
brad
Interested in one of my mods?
Old 05-31-2011, 12:54 AM
Color: Red/Silver
Brad,
Umm, possibly not on the way back with the empty trailer. Did use it when loaded with the cattle. Does the tow/haul make a difference to the rpm? Does it not let it go into the last OD gear?
Thanks
Old 05-31-2011, 12:56 AM
Color: Red/Silver
Brad,
Also, if yes to the post above, is the 4.10 ratio actually happening in the 4th gear then? Anyone know a link to show the ratio through all the gears?
Thanks
Old 05-31-2011, 01:14 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
The 68RFE gear ratios are:
1st 3.23:1
2nd 1.83:1
3rd 1.41:1
4th 1.00:1
5th 0.81:1
6th 0.62:1
Reverse 4.44:1
4.10 x 664 (Rough estimate of tire rpm with 245/75R17) / 60 = 45.37 rpm per mph in direct (4th)
100 kmh (Estimated)
4th - 2813 rpm
5th - 2279 rpm
6th - 1744 rpm
Gene
Old 05-31-2011, 12:49 PM
Color: Red/Silver
Awesome guys. Thanks for that info Gene.
With that kind of 6th gear rpm, it makes me wonder, why would someone need to go to 3.73 or 3.42???
Old 06-01-2011, 10:57 PM
dem123 dem123 is offline
Vehicle: 2011 Laramie Longhorn
Trim Level: Laramie Longhorn
dem123 is on a distinguished road
I have a 4.10 in mine and the RPM is the same as yours. The auto is the way to go!
Thanks...
Old 06-01-2011, 11:35 PM
brad12kx's Avatar
Rep:2581
Brad,
Thanks
Brad,
Thanks
Yes to both.
I see Gene K has you covered with the gear ratios.
Enjoy your Ram!
brad
Old 06-02-2011, 01:09 AM
Rep:2929
Whisky Creek you made the right call on the rear end
i think i saw a question about gear ratios & i may be able to answer it
it is a common mistake they many people make, myself included many years ago
torque is pulling power, using the same engine you can get more pulling power using the transmission & or rear end ratio
taking your 6.7 L engine as an example
you have 2 choices of transmission, standard or automatic, the lower gears in the transmission allow the engine to produce more torque, the more torque the more you can pull
next lets just say you have the automatic transmission & the 6.7L engine, the transmission knows when to shift, whether it is on a hill or flat land, it shifts accordingly
now you toss in the rest of the drive train, the rear end gears
Here is where a lot of people get confused
you have an engine that is more than adequate to supply the horse power
you have an automatic transmission that can read what gear it needs to be in
you have a rear end that can have different ratios, you buy what you need the vehicle to do
the 3.42 is usually a very TALL gear, great for mileage & low RPM, not so good for towing, because of LOW TORQUE
the 3.73 is a bit more of a fuel user, a bit higher RPM to do the same speed, a bit better for towing
the 3.92 or 3.99 are mid range rear end ratios, you lose more MPG, your torque increases as does your RPM doing the same speed, easily pull 4 horses any where
then we are at your 4.10s, less MPG again, your RPM increases doing that same speed, but, you can pull almost anything any where, because your torque is way up from the others
then you have other ratios like the 4.56, etc. again less MPG, higher RPMs, tons of Torque
3.55 Axle Ratio vs. 3.92 Axle Ratio sincebeen Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 35 08-01-2016 01:57 PM
Speedometer calibration after gear swap? Red05Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 03-16-2011 11:22 PM
axle ratio and towing vitaminp Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 08-02-2010 11:46 PM
Axle Ratio Shades64 2010 Dodge Ram Forum 16 03-28-2010 05:58 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 09:25 AM
