Old 05-31-2011, 12:59 AM
racerx9987's Avatar
racerx9987 racerx9987 is offline
Vehicle: 2011 ram crew cab sport
Trim Level: sport
Color: blue
Rep:24
racerx9987 is on a distinguished road
Default Need help once again
Original plan was to get cragar soft 8 found some ion alloy 179 in 17x9 with a 0 offset. Was wondering if 295/70/17 would fit without rubbing or 285 is a better choice. I am currently running the stock 20s with a stock suspension. I do not want a leveling kit right now and also would like to do without spacers. Any help would be appreciated.
Going with the nitto trail grapplers if that makes a difference.
Thanks, Nate
Old 05-31-2011, 01:03 AM
Rep:2664
go to TIRERACK website
follow all the prompts
it will tell you if your choices will fit
you can go as far as seeing on a truck like yours
Old 05-31-2011, 04:24 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
It'll be really close with 0mm offset and 295's. From what I've seen and heard, 285's are about as big as you can go with stock suspension. Although, with a more negative offset, I think the 295's will clear. If not, a 1/4" will be all you need.
Old 05-31-2011, 04:25 AM
jcasey10's Avatar
Rep:869
I just saw you said they were trail grapplers. With the lugs on the side of those tires, you might run in to problems. It'll be close.
Old 05-31-2011, 10:46 AM
racerx9987's Avatar
Trim Level: sport
Color: blue
Rep:24
Okay thanks a lot I will probably just order the 285's then should fit if i absolutely have to I will get spacers. Any other input is appreciated
