Bilstein B6 Heavy Duty Shock Install w/Pics - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-04-2011, 05:38 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
nice write up bud...ill add to your reps for that
Old 06-04-2011, 08:16 PM
wolfman10's Avatar
wolfman10 wolfman10 is offline
Trim Level: SLT- Lonestar
Rep:188
wolfman10 has a spectacular aura aboutwolfman10 has a spectacular aura about
Originally Posted by 57hemisport View Post
wrong pic.
heres the one...
Yeah getting to the bolt was easy but I was talking about the blind nut, that was the hard part.
Originally Posted by DOZER View Post
Any particular reason you went with the HD's and not the 5100's? Just curious. I have a set of 5100's and an HBS 2" leveling kit waiting for my new wheels and tires.
I have a 2wd not a 4wd.
-Cody
My Build: http://www.ramforumz.com/showthread.php?t=86853
Old 06-04-2011, 08:18 PM
wolfman10's Avatar
Rep:188
Thanks I appreciate it.
-Cody
Old 06-04-2011, 08:26 PM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2009 Ram 2500 Quad cab 4x4
Color: Inferno Red
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER
Gotcha just thought one may have been a better choice than the other.
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 06-04-2011, 08:56 PM
wolfman10's Avatar
Rep:188
Yeah if those would work on the truck and give me a couple more inches of lift I would've.
-Cody
Old 01-09-2014, 09:49 AM
henryj1978 henryj1978 is offline
Vehicle: 2016 RAM 2500 Mega Cab
Color: Grey
henryj1978 is on a distinguished road
I finally got around to installing the shocks I had order. Here is a simple write up.
I started with the rears thinking they would be easier, but that really turned out to not be true. So jack up the truck and put jack-stands under the frame so that you can remove the tires release the load on the suspension. Once you get to that point you will need a crescent wrench and a 13/16 socket w/ a ratchet wrench to remove the bolts. Go ahead and remove the the lower bolt by using the wrenches injunction. Don't worry about the shock it shouldn't shoot out, it's not like a spring. After that you will need a buddy with skinny hands and arms to reach the blind nut that it at the top of the shock mount. To make it easy on your arms you may also want to remove several of the screws that hold the wheel well liner in place so that you can get the socket in place and to remove the bolt. Once the bolt is removed I would use some white grease to put on the bushings and the sleeves that run in the bushings just to make sure nothing squeaks. Just a personal preference. After that bolt everything back up do the same for the other side, mount the tires and the rear is done.
Move on the the front, do the same thing jack it up and place jack-stand on the frame, remove tires. After all that is done you will need to use two crescent wrenches to remove the top nut off of the shock, one to hold the piston in place to keep it from spinning and the other the remove the nut. Once that is done you will need I think it was either a 13mm or 14mm one of those too to remove the two bolts from the bottom of the shock. After that slide the shock out and spray the new shock with white grease and bolt the bottom up. NOW, if you have a leveling kit on your truck you will run in to this problem as I did, you will not be able to get the nut to come close to the threads without a load on the suspension. SO, mount the tires back and a slowly lower the truck back down towards where it puts a load on the suspension and compress the spring so that you can tighten the nut on top of the shock. Once you get to that point make sure the the bushings is lined up in the whole correctly. After that take the two wrenches and tighten down the nut. Mount the tires and remove the jack and you are done!
As for quality, these shocks make the truck feel like it is riding on glass. No more feeling every little crack or slowing down to a snail's pace to make it over speed bumps, dips and humps. I would recommend these to anyone.
I'm trying my best to keep the pictures in order. Also there are these little thin lock rings on some of the lugs that hold the wheel on and make it very hard to pull it off, do your self a favor as I did and take them off. One on of the pictures look at the front oem shock and see how the bushings are ordered you will need to repeat this with the new bushings.
Enjoy!
Thanks for the write up. I Have a 2010 1500 Laramie 4x4. My front strurt looks diffrent. Has anyone done those. How difficult was it
Bilstein heavy duty or 5100??? Hemiram 05 LD RAM - General Discussion 1 05-29-2011 01:19 AM
Need To Tow Something Heavy? How About 800 Ft. Lbs. Of Torque? RamTech LD RAM - General Discussion 5 02-14-2011 08:43 AM
Iron Cross Heavy Duty from Realtruck.com? caper10 2010 Dodge Ram Forum 2 01-01-2011 08:21 PM
Rocky Mountain Automotive Press Association names Ram Heavy Duty 2010 Outstanding Tr 1970 Charger Automotive Industry News and Dodge Press Releases 0 04-15-2010 09:56 AM
2000 Ram Offroad - Bilstein shock part # ROKNK5 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 08-31-2009 04:57 PM
