Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Warranty Issues
Old 03-18-2011, 09:50 PM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
Default Front Diff. leak caused by the level kit?????
I noticed tonight that the front diff is leaking on the passenger side. The seal where the CV shaft enters the housing. I have warranty and was wondering if the level kit could be blamed for the leak?? Thought I'd ask before I call the shop!
Old 03-18-2011, 10:19 PM
A leveling kit would not change the pinion angle enough to cause premature failure.
Old 03-18-2011, 10:28 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
I had the exact issue and my struts were shot ! I got them replaced under warranty about a month ago and they told me the leveling kit was not a factor !
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
Old 03-18-2011, 10:51 PM
CapperRAM's Avatar
Rep:205
Interesting!! Thanks Fellas
Old 03-18-2011, 11:05 PM
sk8noregon's Avatar
Rep:637
Ya, you should have no worries with warranty, now I'm wondering about the passenger side CV though now that someone had the exact same issue on the same year Ram ?
Old 03-18-2011, 11:09 PM
ScatPak07's Avatar
Rep:970
Ya I do not think that would cause the damage your having. It does put the CVs on an angle but not enough to do that
Old 05-23-2011, 11:40 AM
marioman marioman is offline
Color: Mango Tango
marioman is on a distinguished road
I've got 17 thousand km on my Ram and already have had to do two of these axle fixes. I am really starting to wounder if it does have anything to do with the leveling kit i have installed, the dealler has not noticed i have it installed yet so i waven't had them try and say it's from that. Also my truck has a nasty shake under accelleration when in 4x4 if anybody here can give me any wisdom on what to do with these problems that would be appriciated the mecanics at the dealership are real idiots! Thanks
Old 05-24-2011, 01:11 AM
hemitrx4's Avatar
hemitrx4 hemitrx4 is offline
Vehicle: 2008 Dodge Ram Quad Cab
Trim Level: TRX4
Color: Black Crystal Pearl
hemitrx4 is on a distinguished road
I also have had my passenger side front axle seal replaced under warranty and was told by the dealership that it was a known problem and that the manufacturer of the part was working on it. I was also recently told that putting a leveling lift on would void my drivetrain warranty because Dodge says it changes the front driveshaft angle. They say that any after market parts void warranty and are getting the dealerships to start sending pictures for warranty work. I had to put my stock intake back on to get the egr valve replaced under warranty.
2006 vibration 55mph rake1 Suspension 41 03-07-2014 07:52 PM
2 1/2" Front Level Lift Spacers BigHornRam2006 Suspension 3 04-07-2011 03:02 PM
Front diff locks glhsguy 5.9L V8 Specific Topics 3 02-20-2011 08:50 PM
Front Axle leak info gregster 2010 Dodge Ram Forum 10 03-09-2010 02:10 PM
