Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 05-31-2011, 06:30 PM
XRMECH XRMECH is offline
Vehicle: 2001 ram 1500 5.9 laramie 2wd
Trim Level: laramie
Color: blue
XRMECH is on a distinguished road
Default 2001 Ram 1500 ABS and Brake light comes on at 60MPH.
Hey people, i've been lurking and looking for a solution to this problem.
so here are the symptoms.
after a few seconds of 60MPH driving the abs and brake light on the dash comes on and stays on untill i turn the engine off and when i restart it the light are off until i hit 60 again. everything works fine,the speedo,brakes,etc.
I have changed the rear wheel speed sensor on the differential and changed the gear oil in the diff. Still the same problem. The brake fluid is fine. I also hooked up the code reader and nothing is stored as far as codes go.
It seems to be running fine just the lights are annoying.
any help would be appreciated and the wife would be happy to.
Glad i found this place too.
Old 05-31-2011, 07:23 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
pretty sure if they both come on at the same time your losing pressure in the system ,but your not losing any fluid though are you?
-PAT-
Old 05-31-2011, 09:07 PM
Trim Level: laramie
Color: blue
I'm not losing any fluid.
Ikeep checking it every other day.
Old 06-01-2011, 11:31 AM
triflex triflex is offline
Vehicle: 1999 Dodge Ram 350 Dually
Trim Level: unknown
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
triflex is on a distinguished road
Don`t know if this helps but My speedo stopped and the abs and air bag light was on. Turned out to be a bad ignition switch and a broken wire in that area.
