check engine codes - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-01-2011, 01:18 PM
tomhrrs69 tomhrrs69 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Quad cab, Big Horn
tomhrrs69 is on a distinguished road
Default check engine codes
I was wondering if there was a way to retrieve the check engine codes without using a scanner on a 2011 Ram 1500? I would like to have a general idea what the problem is before I take it to the dealer.
Old 06-01-2011, 01:52 PM
Rep:2946
some auto parts stores have a Code Reader, it is not as good as the Reader that the dealership uses, it points you in a General Direction to look at, usually it does not pinpoint the problem
I suggest that you NEVER tell a dealers service dept. what a code reader indicated, just tell them the vehicles symptoms. If you tell them what you discovered & that they should replace this or that, they Will change it, even if they know for a fact that it is not the problem
I would suggest, don't let anyone clear the codes, leave them stored for the dealer to fix & then clear them
Old 06-02-2011, 11:43 AM
thanks for the info. the check engine light just went off this morning, but I'm going to go ahead and call the dealership anyways and have them check things over.
Check engine light southpaw5m 4.7L PowerTech V8 Specific Topics 11 06-08-2011 12:34 PM
New FIPK K&N Filter then check engine light? Ostranza 5.7L V8 Specific Topics 4 12-04-2010 01:59 PM
Installed K & N Intake, immediately threw off check engine light...help! 20ram08 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 11 05-05-2010 07:52 PM
Reading check engine light codes baldman 79 5.9L V8 Specific Topics 5 03-23-2010 09:03 AM
Check Engine Light On cubman3 4.7L PowerTech V8 Specific Topics 7 12-01-2009 03:09 PM
