Old 06-01-2011, 03:33 PM
ram 98 318ci ram 98 318ci is offline
Vehicle: 1998 Dodge Ram SLT Laramie
Color: Green / Silver
Rep:22
ram 98 318ci is on a distinguished road
Default High idle???
i have a 98 ram 5.2l and it has around 78k miles on it, i have a high idle in nuetral and park around 1k and in drive around 850ish i changed the TPS and IAC with little luck and Seafoamed the motor to help clean it out, it helped a little but didnt cure it, also it doesnt have a air leak.
any ideas?
Old 06-01-2011, 03:56 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
any ideas?
The 5.2 I noticed does idle higher then the newer engines around 800-1000 is actually normal. Once the engine warms up of course the idle drops a bit. Try cleaning out the throttle body.
Old 06-01-2011, 04:58 PM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
I agree with ramvan2500 about cleaning the TB.
Also, check the throttle cable that attaches to the throttle body and see if it is able to return to idle properly. There might be debris keeping the cable from retracting all the way, causing the truck to idle a little too high.
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
Old 06-08-2012, 03:30 PM
Rep:22
Fixed it was the TPS wiring that connected next to the coolant fluid on the intake manifold
High idle at start up? akt 5.7L V8 Specific Topics 14 01-09-2011 05:45 AM
High idle? ry345 Dodge Ram General Discussion 2 01-06-2011 11:46 AM
High Idle RPM, and (maybe) tranny problems? greenmachine16 5.9L V8 Specific Topics 0 11-25-2010 04:47 AM
High Idle sasdelivery713 4.7L PowerTech V8 Specific Topics 3 10-19-2010 06:27 PM
High idle after CAI JR23 4.7L PowerTech V8 Specific Topics 11 04-05-2010 09:46 PM
