wanna lift my 97 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-01-2011, 09:58 PM
SPC.Brinkmeyer's Avatar
SPC.Brinkmeyer SPC.Brinkmeyer is offline
Vehicle: 1997 Ram 1500
Trim Level: SLT/Laraime
Color: Red/Silver
Rep:14
SPC.Brinkmeyer is on a distinguished road
Default wanna lift my 97
i currently have a 97 1500 single cab shortbed and i want to get some more lift out of it. what im thinking i want to do is this...
i want to move the rear hangers and the front spring buckets down 2-3" and reweld them on.
i already have a 3" Body Lift on the truck as well as 2" coil spring spacers and 3" blocks in the rear and have air shocks in the rear aswell.
now my question is what all do you say that i will need to change to compensate for the dropped hangers and spring buckets? i want to compare your lists with the list i already have.
1) ive been told that the stock 4link can only take 3" of lift to still enable full flex i dont like the design of the bars stock so i want to replace them anyway with tubing and new ends and possibly a better design.
2) im sure i will need sway bar blocks to lower them from the frame along with possible longer sway bar endlinks sence the P.O. didnt use them when they installed the 2"spacers.
3) a drop pit and idler arm or a bracket to drop the stock idler arm down a couple inches.
4) will need longer brake lines to account for the axle being away from the frame
5) im unsure of this one... will i need to do anything as far as drive shafts go... will the stock ones be fine or will they need to be longer aswell
thanks for any help
ANOTHER USLESS POST BROUGHT TO YOU BY NOONE
Old 06-02-2011, 11:40 PM
Tooadvanc3d
Im willing to bet that you will need to alter your driveshafts or you with get vibrations or possibly binding. Youll need longer shocks also. I really doubt your going to save yourself much money if at all. If you need new control arms you going to want to go with a long arm set up and I would use .250 wall DOM tubing and dont forget to factor in your castor angle
Old 06-05-2011, 11:12 AM
Color: Red/Silver
Rep:14
any other ideas
Old 06-05-2011, 12:30 PM
You may have to drop the intermediate drive shaft carrier bearing with a spacer at the mounting bracket to correct your pinion angle.
Old 06-05-2011, 12:42 PM
Color: Red/Silver
Rep:14
humm. so do you think it would be better to do this or to buy a 4" lift
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 06:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
98 4wd wanna lift 984wdram Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 05-23-2010 11:08 AM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 12:28 PM
