Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 06-02-2011, 01:28 AM
jpmassa jpmassa is offline
Vehicle: 1991 Ram D250 5.9L
Trim Level: LE
Color: White peeling to primer
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
jpmassa is on a distinguished road
Default Idle Speed Motor (AIS) problems code 25
Hello. Any one offer some advice on fault code 25 problems? Recently had to replace the SBEC / engine computer. After replacement, got a new fault code I never had before = 25. Sure enough, the idle speed motor (AIS) motor attached to the throttle body stopped working. Low idle, engine wants to die out at idle especially under load.
Coincidence that the motor failed after ECM changed? I replaced the idle speed motor for $75, but problem is not fixed, code 25 remains. I'm thinking maybe the engine computer is faulty here .. can't tell. No diagnostics in the CHilton manual for this one. Can't find any wiring problems. Suggestions for diagnosis? Or just replace the AIS motor again or replace the ECM?
Thanks for reading, Jim.
Old 06-03-2011, 11:46 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I hope you've gotten some help from the other post of this issue. I'd also like to extend a warm welcome to you here, how about using the link in my SIG to jump over to the Newbie Checkin and posting a few photos of the truck?
Old 06-04-2011, 12:06 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
All I can think is to try to wiggle test. Wiggle the wires to the AIS and see what happens. Also try the rap test, rap the AIS and see what happens.
Old 06-05-2011, 10:59 AM
Trim Level: LE
Hey I'll pencil those tests into the Chilton's manual, just before the 'buy all the parts and return them if you're wrong' test.
Idle speed for 99 5.2 Dieselkiss 5.2L V8 Specific Topics 6 03-01-2012 06:46 PM
Idle problems rflearyjr 5.7L V8 Specific Topics 3 05-03-2011 12:28 PM
4.7 idle problems Audiowizard 4.7L PowerTech V8 Specific Topics 10 02-24-2011 02:14 AM
Low Idle Speed Straightedge 5.7L V8 Specific Topics 5 03-14-2010 09:18 AM
99 5.2 idle speed Dieselkiss 5.2L V8 Specific Topics 1 03-09-2010 07:53 PM
