Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-02-2011, 10:34 AM
Rockmun Rockmun is offline
Vehicle: 2006 Dode Ram
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rockmun is on a distinguished road
Default Yellow Engine Light on After Jumping
Hi all, I'm new to this forum and a new Dodge owner, so I'm learning to navigate.
I just bought a '06 Ram w/ the 5.9L Cummins. No problems until yesterday: I left the key in the ignition (in "run") and drained the batteries.
I jumped the truck w/ no problems, but the yellow engine symbol light is now on.
Any ideas on what might have happened? Any help is appreciated.
Old 06-02-2011, 11:16 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Need to pull the code and take it from there.
You can get the code if you have a programmer or maybe you can take it to local auto store and have them pull the code for you. Could be a free service too.
Old 06-02-2011, 11:27 AM
Rep:2755
Welcome to this RamforumZ from way down here in San Diego California
I am not sure about the Rams back then, but the newer ones will not charge themselves back up just by running the engine. The battery(s) on the new ones have to be re charged with a battery charger to get all the way back to full charge again, running it only gives it a surface charge, not a deep cycle charge.
Another thing that i read about, taking the connections off the battery for 10 or more minutes will reset the system usually. Take the cables off, clean the posts & cable connections, charge the battery using a battery charger, connect everything back up & the warning light should go out. If it doesn't, then its time to look elsewhere.
Good Luck
Old 06-03-2011, 08:03 PM
Cthulhu Cthulhu is offline
Vehicle: 2006 Dodge Ram 3500
Cthulhu is on a distinguished road
You can get your code (no explanation) by turning your key from off to run and back (IIRC) 5 times..
2006 - RAM 3500 Megacab - CTD - K&N CAI - LightForce Driving Lights - ReTrax Bed Cover
Jumping engine temp? jordanj273 5.7L V8 Specific Topics 4 05-27-2011 06:27 PM
O2 sensor cause check engine light to come on pike16 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 21 03-20-2011 02:06 PM
check engine light MOPAR stallion 5.9L V8 Specific Topics 24 11-26-2010 04:12 AM
95 2500,CHECK ENGINE light video,tell me what get, hooptycuztom 5.9L V8 Specific Topics 6 12-20-2009 11:34 PM
Check Engine Light after Rain GsxR1000Ryda 5.9L V8 Specific Topics 9 12-14-2009 11:12 PM
