Old 07-01-2011, 09:38 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Thats going to be awesome! Can't wait to start doing some big stuff to mine! I'm going to do the 4.10 gears and true trac first.
Old 07-04-2011, 10:18 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default looking foward to --
see the out come ramtex. same parts i was thinking about. speed
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 07-08-2011, 11:09 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
My heads came in yesturday still waiting on pushrods and cam.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-08-2011, 11:28 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
drooooooolssssssss
Old 07-08-2011, 11:38 AM
916Timmy's Avatar
Rep:1443
Who's putting it all together for ya?
Old 07-08-2011, 12:19 PM
RamTex's Avatar
Color: Stone White
Rep:366
My friends, and my car club buddies are gonna help plus all you guys cause i dont have the cash to get it all installed... Its gonna be a job thats for sure. Im trying to draw up a plan of attack but im gonna need all the help i can get. I plan on doing the torque converter first then the rest. I would be nice if a had a breakdown of what i need as far as tools and a list of steps on how to pull the tranny and install the TC then a list of steps for the rest of the install cause if it were just me i would be winging it... which would not be a good thing. Any help on this would very appriciated.
Old 07-08-2011, 02:08 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Here are the procedures for trans removal:
1. Disconnect the negative battery cable.
2. Raise and support the vehicle
3. Remove any necessary skid plates
4. Mark propeller shaft and axle companion flanges for assembly alignment.
5. Remove the rear propeller shaft
6. Remove the front propeller shaft, if necessary.
7. Remove the engine (1) to transmission (3) structural dust cover (2).
8. Remove the exhaust support bracket from the rear of the transmission.
9. Disconnect and lower or remove any necessary exhaust components.
10. Remove the starter motor.
11. Rotate crankshaft in clockwise direction until converter bolts are accessible. Then remove bolts one at a time. Rotate crankshaft with socket wrench on dampener bolt.
12. Disengage the output speed sensor connector from the output speed sensor
13. Disengage the input speed sensor connector from the input speed sensor
14. Disengage the transmission solenoid/TRS assembly connector from the transmission solenoid/TRS assembly
15. Disengage the line pressure sensor connector from the line pressure sensor
16. Disconnect gearshift cable (1) from transmission manual valve lever
17. Disconnect the transmission vent hose from the transmission.
18. Support rear of engine with safety stand or jack.
19. Raise transmission slightly with service jack to relieve load on crossmember and supports.
20. Remove bolts securing rear support and cushion to transmission and crossmember.
21. Remove transfer case, if necessary.
22. Disconnect transmission fluid cooler lines at transmission fittings and clips.
NOTE: When disconnecting the transmission oil cooler lines, it is necessary to replace the line clip that is located on the oil pan stud. The retention force of the clip is severely degraded upon removal.
23. Remove all remaining converter housing bolts.
24. Carefully work transmission and torque converter assembly rearward off engine block dowels.
25. Hold torque converter in place during transmission removal.
26. Lower transmission (2) and remove assembly from under the vehicle.
27. To remove torque converter, carefully slide torque converter out of the transmission
Here are the steps for tc removal:
1. Remove transmission and torque converter from vehicle.
2. Place a suitable drain pan under the converter housing end of the transmission.
CAUTION: Verify that transmission is secure on the lifting device or work surface, the center of gravity of the transmission will shift when the torque converter is removed creating an unstable condition. The torque converter is a heavy unit. Use caution when separating the torque converter from the transmission.
3. Pull the torque converter forward until the center hub clears the oil pump seal.
4. Separate the torque converter from the transmission.
I'm sure there are some shortcuts but this is a copy and past from the Dodge Service Manual.
Old 07-08-2011, 02:25 PM
RamTex's Avatar
Color: Stone White
Rep:366
yeh i was expecting it to be that much of a pain but hey such is life i may just see if i can get an install for cheap... It even sounds a bit dangerous i like having all of my fingers...
Old 07-08-2011, 02:34 PM
CHVYKLR's Avatar
Rep:252
a couple of buddies and a floor jack and you can drop that thing no problem.
Old 07-08-2011, 02:38 PM
RamTex's Avatar
Color: Stone White
Rep:366
Looks like install for the TC will be around $500 to $700 that sound s about right does this check with you guys? Yeh im gonna chat with my buddies and see how confident they are on getting it done ill get it done one way or another.
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Dodge 5.2L (318) Magnum Cylinder Heads Refurbished (Pair) ramvan2500 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 06-02-2011 11:10 PM
valve covers? bfinley Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 8 12-18-2010 12:47 PM
