Wheel Alignment Void My Warranty From Another Company? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Warranty Issues
Old 06-05-2011, 10:40 AM
RacerX RacerX is offline
Vehicle: 2011 Dodge Ram 1500 ST
Color: Sliver
RacerX is on a distinguished road
Default Wheel Alignment Void My Warranty From Another Company?
Hey Gang,
Just wondering if a non-factory wheel alignment would void your warranty I really don't want to pay dealership price as I can get one for $60.
Old 06-05-2011, 01:04 PM
No, it will not.
Old 06-05-2011, 06:54 PM
07yt1500thunderroad's Avatar
07yt1500thunderroad 07yt1500thunderroad is offline
Vehicle: 2012 passat tdi se w sunroof
Rep:70
07yt1500thunderroad will become famous soon enough
Nope, but you shouldn't need an alignment this early....have you upgraded your suspension or something?
Old 06-06-2011, 05:59 PM
rtkman's Avatar
rtkman rtkman is offline
Rep:167
It wont affect your warranty no. There is no warranty on alignment anyways once you've had it for a bit.
Old 06-07-2011, 02:21 PM
Scjon03 Scjon03 is offline
Vehicle: 2013 Ram 2500
Trim Level: Laramie Mega Cab
Color: Gray
Rep:71
Scjon03 will become famous soon enough
My alignment was bad from the start. The steering wheel was off center and pulls to the right. Got it fix but still pulls to the right a little.
2013 Ram 2500 Mega Cab Laramie 4x4
Old 06-07-2011, 06:13 PM
rtkman's Avatar
Rep:167
It may not be an alignment issue now. it could be tire pull. Try rotating the tires.
Old 06-10-2011, 07:13 PM
Rep:70
my truck did the same thing turned out the front tire on the right had separated and caused the truck to constantly pull right look at your sidewall and see if it is bulging or put the spare on the front on which ever side it seems to pull to.
P.S. if you still have the goodyears they are junk and easily round out and separate so i would buy a new set of tires!
Old 06-11-2011, 11:37 AM
Color: Gray
Rep:71
I had a tire blow out the other day. Replaced all 4 tires and it still pulls to the right a little. Just going to get it fix after I get back from my deployment.
Old 06-29-2011, 01:17 AM
Color: Sliver
Thanks everyone for your quick and informative replies after I got the alignment the computer print out said I was within factory specifications.
I also found out that my mechanic works for a Dodge Dealership full time when he is not taking side jobs under the table so that was good to know.
Futhermore when I drove on the highway I still had a bit of a pull and had to steer to compensate, I thought my steering wheel was off too but rtkman is probably right about needing your tires rotated in this case.
I drove over 2000kms while needing a wheel alignment, but after I got it done I held the steering wheel straight as much possible to straighten out the wear(it didnt stay straight over 60kms). But now almost 1000kms after the alignment and keeping it straight as much as possible it doesnt pull and drives straighter. I probably need to still get them rotated if I have time or just wait until I buy new wheels and see if I have any issues after that.
07yt1500thunderroad
I needed a wheel alignment because I hit a curb to avoid some a-hole damaging my new truck in Canada's Winter Wonderland.
Scjon03
If it was messed up straight from the dealership something is for sure wrong on dodge's end I hope it is nothing to expensive.
Old 06-29-2011, 02:40 AM
Rep:2929
the factory tires seem to CUP way to easy
I changed my chrome clad 20" rims & stock tires out for a good brand
the original rims & tires are now in my spare bedroom
Suspension, Tire, and Wheel Guide 57Hemi08 Dodge Ram Wheels And Tires 169 07-19-2017 01:26 AM
Wheel alignment ejk78 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 04-14-2011 04:12 AM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 11:40 PM
2009 6.7 Exhaust Mods Jd316 Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 12 10-28-2010 01:37 PM
Would headers void my engine warranty? 2Dodges 2010 Dodge Ram Forum 1 09-16-2010 11:58 AM
